Driver from prescott 800 fsb 800 dual channel DDR 400
  • Dick
    Dick May 11, 2010
    Memory does not need a driver, nor does a processor. What is your question?
I have a dell dimension 3000. I want to add a 2nd monitor. I believe the video is integrated, Does the unit have a slot to add a video card. What kind of card should be added?
The Dimension 3000 Springdale G chipset supports AGP 8X cards, integrated video, integrated audio, ICH5, 533/800 MHz FSB, dual channel DDR 333/400 memory, integrated Serial ATA, and the Intel Pentium 4 Prescott.
The AGP 8X slot refers to Advanced Graphics Port. You can add a AGP video card if you motherboard has that slot. Usually that slot is encased by a green plastic enclosure .
Aug 02, 2011 | Dell Dimension 3000 PC Desktop
Motherboard specification
Intel 865GV Chipset Pentium 4 Main board,
Supports Prescott CPU
FSB800, DDR 400, SATA 150 Specifications
arrow_bullet.gif CPU
  • Supports Intel Pentium 4 Socket 478 processors(Prescott and Northwood) with 800/533/400MHz FSB
  • Supports Intel Hyper-Threading Technology
arrow_bullet.gif Chipset
  • Intel 865GV/ ICH5
  • Integrated Intel Extreme Graphics 2
  • Supports Advanced Configuration and Power Management Interface (ACPI)
arrow_bullet.gif Memory
  • Two 184-pin DIMM sockets
  • Supports 2 DIMM Single/ Dual Channel DDR 400/ 333/ 266 memory (Max. 2GB)
arrow_bullet.gif Graphics
arrow_bullet.gif SATA 150
  • 2 channel Serial ATA 150MB/s data transfer rate
arrow_bullet.gif Audio
  • 6-Channel AC 97 CODEC on board
  • Professional digital audio interface supports optical S/PDIF Output
arrow_bullet.gif System BIOS
  • Supports Plug-and-Play (PNP)
  • Supports Advanced Configuration Power Interface (ACPI)
  • Supports Desktop Management Interface (DMI)
  • Write-Protect Anti-Virus function by AWARD BIOS
arrow_bullet.gif LAN
  • On board 10/100Mb LAN
arrow_bullet.gif Internal I/O Connectors
  • 3 x PCI slots
  • 1 x Floppy Port supports up to 2.88MB
  • 2 x Ultra DMA 33/66/100 Connectors
  • 2 x Serial ATA 150 Connectors
  • 2 x USB 2.0 headers (Each header support two USB 2.0 devices)
  • 1 x CD-IN, 1 x AUX-IN
  • 1 x FP-Audio header
arrow_bullet.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 mouse
  • 1 x Parallel Port, 1 x Serial port
  • 1 x VGA Port
  • 1 x Audio connectors (S/PDIF Out, Surround Out, Center/Sub, Lin-out, Line-in, Mic)
  • 4 x USB 2.0, 1 x RJ-45 LAN Connector
arrow_bullet.gif Miscellaneous
  • Micro ATX form factor (244mm*234mm)
  • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
    hope this helps
Jul 07, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
Need prescott 800 ddr 400 sound card drivers
ITALIANO
Sceda madre ASROCK Prescott 800, FSB 800/DDR400 Dual Channel
Comme deve ataca PANEL1
POWER SW o o
RESET SW o o
HDD LED o o
POWER LED o o o
Grazie
Nov 18, 2010 | Asrock P4I45E-R3 P4 845E FSB800 DDR400...
Does the MB support an Intel Prescott 3,06 ghz fsb 800mhz processor?
that is a socket 478 board. it supports northwood and early prescotts. prescotts at 3.06 with the 800mhz fsb were made in both socket 478 and lga 775 forms, so you have to make sure that your processor is indeed a socket 478 model.
Nov 06, 2010 | Abit IC7-G I875P;SOCKET 478;800MHz...
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Mortherboard
CPU:
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology Chipset: Intel 865PE / ICH5-R
Supports Dual Channel DDR 400 Memory
Supports Advanced Configuration and Power Management Interface (ACPI) Memory: Six 184-pin DIMM sockets
Supports Single/Dual Channel DDR 400 memory (Max. 4GB). Audio: High quality 6-channel AC'97 audio with S/P-DIF function with JAck Sensing IDE/SCSI: Dual Ultra DMA 66/100 IDE controllers integrated in ICH5R- up to four Ultra ATA drives
Serial ATA/150 controller integrated in ICH5R- Up to 150MB/sec transfer speeds
2 channels Serial ATA 150MB/s data transfer rate via Silicon Image PCI controller
GigaRAID IDE RAID Controller I/O Connectors: PS/2 Keyboard and mouse, 1 x Parallel, 2 x Serial, 4+4 x USB2.0, 1 x RJ45, 1 x Audio Expansion Slots: 1 x AGP (3.0) , 5 x PCI (2.3), 1 x DPS Additional Features: GIGABYTE Patented Technology Dual Power System 2 (DPS 2)
GIGABYTE Xpress3 Series Software
from the above configuration for the board you can see that it supports up to 4GB ddr max
hope this helps pls appreciate by rating as fixyaa
Oct 05, 2008 | Intel Motherboard
Drivers
driver de audio fsb 800 ddr 400
May 01, 2008 | Asrock 775Dual-880 Pro Motherboard
Computers & Internet Logo
13,857 people viewed this question
David Payne
David Payne
