Question about Kenmore HE2 Plus Front Load Washer
Water isnt sucking out
My washer isnt sucking the water out but only sometimes, and it blinks f-21 whats that? a code?
  • 460 Answers
Code 21 means
Long Drain
if the drain time exceed eight minutes,"F 21" will be displayed, the water valve will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine.
The display will cleared and the machine will turne off after a maximun of eight minuts.
Was this helpful?
Posted on May 12, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Blinking 21 times power red LED
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience
Apr 02, 2014 | Sony KDF-E60A20 60 in. LCD HDTV
F-21 keeps blinking?
you have to clean the pump or you have a bad pump,unplug it,remove the bottom panel,get a shop vac,the center of the pump spins out counterclockwise,have vac ready,turn center cap and vac out water as it comes out,first if there\'s water in the tub suck that out first then go to the pump,when water stops coming out pull out the center of pump and clean it out,usually coins and other lovely smelly stuff in there,go here and look at part number 15 this is the part you want to remove
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-
Parts/Washer-Parts/Model-
MHWZ400TB00/3048/0153200/W0803074/00005?
blt=06&prst=&shdMod
if you have anymore questions i\'m here and good luck,this is an easy repair and these pumps usually can take a pounding
Apr 17, 2013 | Maytag MHWZ400T Front Load Washer
F21 code
F-21 on this washer means long drain which mean s the drain isnt working properly open the lower panel and open the drian sump (might gush water) and make sure that no objects are stuck if you find anything remove it and try the drain and spin option if it does not help or if you dont find anythin replace the drain pump, hope that helps
Sep 04, 2011 | Maytag MHWZ400T Front Load Washer
My front loader washer is blinking the f21, what does this mean?
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Apr 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
HE 2plus problem
Hello, the F-21 blinking is an indication has a too long of a drain out condition, and what actually cause these is when the control call for the unit to drain and the water does not drain out in 8 minutes or less the unit will stop and flash F-21. So try checking the drain pump and pressure switch circuit.
Thanks
Jun 09, 2010 | Kenmore HE2 Plus Front Load Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 11, 2009 | Kenmore 44102 Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
189 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
