Erratic movement of cursor
When using my Synaptics touchpad on my laptop, out of the blue the cursor starts jumping around by itself. I try moving it back to where I want it and it won't respond.
If I attach my external mouse the cursor works fine.
  • 197 Answers
Try to re-install the driver of your touchpad. i suspected it could be the driver issue.
Posted on May 29, 2009
How to stop cursor from floating while typing
The erratic movement of the mouse cursor might be due to the high sensitivity of the touchpad.
Try these steps may be your problem due to the high sensitivity of the touchpad
-Go to the Control Panel (large icon view) > Mouse > Device Settings > Settings
-Under the Synaptics Settings, go to Pointing > Sensitivity > Palmcheck and set the palm sensitivity near the maximum settings and test.
If this didn't help you then simply get the the reginout to optimize your laptop . hopefully you will be able to fix this annoying issue
Jun 23, 2013 | Computers & Internet
Cursor jumps around
Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Jan 28, 2013 | Dell Inspiron dncwix12 Notebook
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
I'll move the cursor to one spot on the desktop and it will move itself to another....windows 7
You mean, the cursor is erratic and moving all around here and there?
Decrease the Touchpad Sensitivity...
I see that your Laptop was shipped with Windows Vista and it seems you are using a Retail version of Windows 7. Specially, HP/Compaq Laptops is designed for Retail versions and you can face some device/driver functionality issues. But, you can still try the followings.
As per my knowledge, your Laptop has the Synaptics Toucpad.
To Change the Sensitivity of the Touchpad:
1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
2. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings. In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
3. Select the PalmCheck option to adjust the sensitivity (decrease it) of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
If the Device Setting tab is missing.....
1. Click Start, in the Start search field type Msconfig and press enter.
"System Configuration Utility" box will pop up on the screen.
2. Click the Startup tab.
3. Search for "Syntpenh" entry and select the checkbox beside it.
5. Click OK. Restart the computer. Perform above step.
If you are still not able to perform the steps, update the driver from following link.
Synaptics TouchPad Driver: ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44969.exe
Restart the Notebook and check for the problem. It should be resolved now.
Aug 22, 2010 | HP Pavilion dv9000z Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
Lately my touchpad welll cursor has been really playing up like when i rest the laptop on my laptop its fine but then when i rest the laptop on my sofa or bed the cursor starts to really play up and clicks...
Hi. I think the problem for your touchpad is just some settings on it, if your using the Synaptics driver for your touchpad you can check the option on the synaptics setting where you can disable your touchpad while you are typing or doing something else on your keyboard. If you could not find this options or settings on your laptop you could just download a software that does the same thing, disable your touchpad while you are typing so that it would not go erratic. here is the link http://tinyurl.com/nte6wu, click on this link it will redirect you to a website where you can download the software, but that is only if could not find the option on your touchpad settings, by the way try also your control panel and look for the mouse icon then for your touchpad settings. Hope this helps
May 17, 2010 | Computers & Internet
ACER ASPIRE 5517 Notebook computer. Erratic cursor
i have seen this problem in other laptops and the mousepad had to be replaced.
Apr 27, 2010 | Acer Aspire One PC Notebook
Synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
May 16, 2009 | HP Compaq nc6220 Notebook
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Computers & Internet Logo
1,165 people viewed this question
David Payne
David Payne
