Question about Refrigerators
Water keeps dripping under the fridge.
I keep getting puddles of water in front of my refridgerator.
  • 192 Answers
In a frost-free refrigerator/freezer the frost that would normally accumulate on the inside wall of the freezer is removed by heaters imbedded in the freezer's walls. Periodically these heaters are turn on to melt the frost which then exits the freezer as liquid water through a drain in bottom. This water accumulated in a pan underneath the refrigerator and is supposed to be removed by evaporation. If the flow of melted frost from the freezer is greater than the evaporation rate in the pan then the pan will overflow and you will get a pool of water on your floor. A bad seal on the freezer door will allow more frost to form inside. Also if you leave the freezer door open a lot you will accumulate more frost. The evaporation rate in the pan can be affected by the ventilation around it. If the vents on the bottom of your refrigerator are clogged with dust it will decrease the evaporate rate in the pan. In addition, many refrigerators have a fan the pulls air around the pan. If this fan has stopped working the evaporation rate in the pan will also decrease.
Posted on May 11, 2009
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I keep walking into my kitchen to find a strange little puddle of water near the front left of the fridge. cannot find a trail from under the fridge so i have no idea where it's coming from. is there a pan...
could be the defrost pan / ck it for crackes / some times it's the water valve leaking through . due to water pressure changes . put a paper towel in disp and see if it gets wet at night . and if you have a large dog that drinks from it at night this also could be the problem ( ha ha // ) but it has happened .mm
Apr 18, 2010 | Refrigerators
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
I have a crosley refridgerator approximatly 8 or 9 yrs. old, and it has started leaking water on the floor. We will find a puddle on the floor about every 2 days. Yesterday, (march 24th), We noticed water...
First make sure than the drain hole in the freezer floor is not clog also check the water plastic lines under the front and back of the refrigerator
Mar 25, 2009 | Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Water leaking under refrig
there is a drip pan under the freg. check the drain hole at the buttom fo the freeze side. make sure it is open.
you can get to the drain pan via front grill. pull the front grill. and you will see the drain pan.
Nov 07, 2008 | Amana SXD524VW Side by Side Refrigerator
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Refrigerators Logo
548 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
