Question about Kenmore 44102 Front Load Washer
Water isnt sucking out
And now it did and the light on the screen blinks f-21, it must be a code or something. is the water pump bad? or is there sumthing stuck in the lines or valve to make it do this?
  • 15,935 Answers
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
Why blinking lights, won't wash, drains water out?
Hello. You didn't provide any brand/model number but the flashing lights are most likely digital error codes flashing in a pattern. For instance, there could be the "clean" light flashing groups of 2 blinks and then 7 blinks or the "sensing" light flashing a certain number of times and then the "rinse" light flashing another number...these error codes will tell you where the problem lies. As a built-in safety feature, the unit will try to wash the dishes but when something fails internally, the program will stop, and then drain out the water, then flash the error code of the part that failed--for example, if the water temp was improper for a certain length of time, a motor pump failure, heater failure, water level wrong--there are many codes. Hope I shed some light on the problem!
Aug 18, 2015 | Dishwashers
Maytag washer mfw9600sq0 f21 code blinking and wont do anything but blink after replacing pressure switch. Pump was also replaced. Pulled the plug for 30 secs to try and reset but still continues. The...
"F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. More than likely the filter is clogged up. Remove the bottom kick panel to get to the filter. Have some towels handy since there will be a bit of water that will come out when you open the filter. Take a look at the video above to show you how to access the pump filter.
Sep 26, 2013 | Kenmore Elite 45986 Front Load Washer
F-21 keeps blinking?
you have to clean the pump or you have a bad pump,unplug it,remove the bottom panel,get a shop vac,the center of the pump spins out counterclockwise,have vac ready,turn center cap and vac out water as it comes out,first if there\'s water in the tub suck that out first then go to the pump,when water stops coming out pull out the center of pump and clean it out,usually coins and other lovely smelly stuff in there,go here and look at part number 15 this is the part you want to remove
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-
Parts/Washer-Parts/Model-
MHWZ400TB00/3048/0153200/W0803074/00005?
blt=06&prst=&shdMod
if you have anymore questions i\'m here and good luck,this is an easy repair and these pumps usually can take a pounding
Apr 17, 2013 | Maytag MHWZ400T Front Load Washer
Ran Cleaning Cycle, lights blinking w/ F- 21min alternating
f-21 is a blocked drain pump.remove the bottom panel,if you have a shop vac get all the water out,you'll see the pump and in the middle there's a piece that you can turn and pull out,first put towels under and around the pump to catch any water that leaks out,turn the part slowly and with your shop vac catch the water with the vac,take your time and open it little by little catching the water with the vac,when you get all the water out twist the middle part out and clean the catch and feel around in the boot and the pump and make sure you have it cleaned out.stick the middle piece back in and start the washer or you can fill it with a gallon of water and put it into a drain cycle and make sure it drains,if it doesn't you cooked the pump and have to replace it,let me know what you find and next time send the model number.
Jul 25, 2010 | Kenmore HE2 Plus Front Load Washer
My car sucks help me please 2006 pt cuiser
I would check into the timing belt sounds like the timing is off.
Apr 13, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
Not cleaning Fills up with water at the bottom. Just not spraying. I took off everything inside to clean it out. Down to the grinding wheel. Pump feels like it running.
The water first gets pushed into the dishwasher from the water supply, then fills up until the float detects the water level, the water then gets drained into the sump pump and either drains to the plumbing or shoots up through the arm inside the dishwasher. Thats a basic cycle anyways. If it is draining into the sump pump like its supposed to, and not coming out through the arm, then something is blocking it or a solenoid/relay isnt working properly on the pump. If its not draining at all, which you would be able to hear if it were from the sucking or gargling sounds, then the same follows, just in different areas. I know its not to technical, just hoping to shed some more light on the situation.
Dec 28, 2009 | Kenmore 15129 Built-in Dishwasher
No Screen on monitor, GREEN light comes on, blinks once, then off
put a vedio card in your computer then, restart your computer.
Jun 16, 2009 | Gateway FPD2185W 21 in. LCD Television
F 21 error code I came down with 1 minute estimated time remaining, and it was still spinning with soap and water in the machine. I checked again 20 minutes later and the water and soap was still in...
"F21" is a long drain error code. This is most commonly caused by something obstructing the drain pump, or drain lines. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
I would begin by checking the drain pump reservoir for small debris. You would be amazed as to what finds its way into these pumps. The link I provided also gives instructions on how to check the drain pump.
If you clear the drain pump and the problem still presists, verify all the drain lines are clear. If all these preliminary checks still result in an error code, more than likely the drain pump is damaged and requires replacement.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
code 21 means
Long Drain
if the drain time exceed eight minutes,"F 21" will be displayed, the water valve will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine.
The display will cleared and the machine will turne off after a maximun of eight minuts.
Was this helpful?
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 44102 Front Load Washer Logo
66 people viewed this question
fordexpert
Mike Squire
Robert Rankin
