Question about Radio Communications
I have a pair of LXT326 Midland 2 way radios. Neither one will respond to the others call button, nor voice transmissions. They are both on the same channel and have no provacy codes set. Each will pi
I have a pair of LXT326 Midland 2 way radios. Neither one will respond to the others call button, nor voice transmissions. They are both on the same channel and have no provacy codes set. Each will pick up other transmissions from other users. Also, when in the scan mode, both will pick the other voice messages, but not the call button. Please HELP!
  • 21 Answers
Try the battery contacts. or replace with fresh batteries. Try setting the same privacy code in each and see if that clears it.
Posted on May 11, 2009
New batteries; worked great for two days; now will not turn on, either unit!
Check your charger.
Check your radio programming.
Post back with further questions.
Best regards.
Jan 02, 2016 | Midland LXT326 Two Way Radio
What voltage DC charger does a Midland LXT326 use?
http://www.buytwowayradios.com/Products/Midland/manuals/LXT-345-manual.pdf
I don't see it in there either. But since the battery is 4.8v, my educated guess would be somewhere around 6v. Its not stated in the manual though, and you can't see it on the picture towards the end where they offer a charger.
I don't know if you can charge by putting your own batteries in there. I'm guessing probably not, they usually put a different contact in there for the battery pack so you don't accidentally attempt to charge standard batteries.
Jul 09, 2014 | Midland Radio Communications
How many batteries connected in series at the battery pack there is?each one is 1.2 Volts, just add each one and add 10% Voltage.The final voltage is it
I want to get a head set for is but i dont know what the dubble prong plugin is called or what size i need to order i know there are 4 or 5 types.
You should be able to put in the make/model number followed by headset and that will get you to the ones you need.
Jan 21, 2013 | Midland LXT326 Two Way Radio
My midland noaa weather alert is stuck in the tone mode and will not go to voice
Good morning, afternoon, evening or night; whatever time of day you you are viewing this solution posting. Thank you for choosing FixYa to assist you with your problem. Your problem is that your weather radio's 'Alert Type' setting is set on Tone and will not change to Voice. To change your 'Alert Type' setting...
1. Press Menu.
2. Press the down arrow button until you see 'ALT TYPE' displayed on your screen.
3. Press Select.
4. Press the down arrow directional button. You should see 'VOICE' on your screen.
5. Repeat step #3.
6. Repeat step #1 to exit.
You should now be able to receive voice alerts on your radio.Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again in the future, and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 28, 2011 | Midland WR-100 Weather/RDS Radio
Lxt326 how to turn it on
press the menu button for three seconds
Jan 18, 2011 | Midland LXT310 2-Way Radio
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
Apr 09, 2009 | Midland 74-109 Weather Radio
Midland GTX800 "X-Tra Talk" 2-way radios will not transmit
Are you sure that the batteries are running well?
Try using alkaline batteries just for testing.
Jan 17, 2009 | Midland 20-Mile, 22-Channel FRS/GMRS 2-Way...
Radio Communications Logo
387 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
