Question about Vizio L37 Television
Vizio Model#:L37HDTV10A After unpluging the HDMI cable & reconnecting it back, I don't have no more HD picture. The Component cable & HD antena works but no HD brodcasting with HDMI connection. Changed the HDMI cables and still have same problem. Even I used another LCD TV & pictures from my receiver and HDMI cables are fine.
  • 3 more comments
  • hamidtronics May 12, 2009
    Thanks, I have one HDMI input & I did all that what you suggest. It's not working.
    I always do that but the last time!!!!! Is it hard to replace it? where can I buy it?
    Thanx, I just found one for $137.00. But, before that I will like to inspect the board. Maybe is broken & might need some resoldering. Thank you for website!
  • Anonymous Mar 24, 2014
    cable to hook a laptop to tv
  • Marvin tamacas Sep 15, 2017
    Can i speak to the tech support
    New Friend:
  • 56 Answers
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
  • phongnv
    phongnv May 12, 2009
    I think the HDMI ports are bad. In the future, make sure you turn off the TV and the Device connect to the TV before remove the cable.
  • phongnv
    This board is very easy to replace. I have 2 of them last week but they all gone. You can try this web site out: www.shopjimmy.com, they may have it. Make sure you get the correct part number.
    Problem Solver:
  • 10 Answers
Just talked to tech support for my vizei 32 inch, they said a master reset is done by unplugging the tv and hold the power button down for 30 sec. plug tv back in and hold the volume down and input button for 15 secs and then try the tv. If this doesn't work the tv needs to be serviced. What a bummer for a tv that has been well taken care of and only owned for 18 months
Posted on Oct 10, 2009
    How can i talk to the tech support
I am connecting Yamaha DVD player to the Vizio M420 NV via HDMI. i have a picture but no sound. how do I gain audio when using HDMI?
HDMI has both Audio and Video (High Definition Multimedia Interface) and should carry both. However, I had this problem with a client just the other day and it turned out that the firmware on his TV needed to be up[graded. Different model TV, but I believe you may need to download the latest software/firmware update via your PC and put it on a flash drive and then flash the firmware on your TV to get it to work. Sorry I don't have the specifics; I was stumped and the Time-Warner guy ended up doing it. I hope this at least sends you in the right direction.
James
Apr 17, 2011 | Vizio Televison & Video
What am supposed to do if my t dosen't have HDMI
Either HDMI to DVI adapter cable if TV has DVI in. Or component video cable (Green,Blue,Red jacks, plus White,Red for audio. Both will do HD.
May 01, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
HD to SD/SD to HD channel switch causes the picture to disappear
try using component cables instead if you are using an HDMI cable to connect to the tv to the STB
Jun 07, 2009 | Vizio GV42L 42 in. LCD Television
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Vizio hd L37 tv not showing a clear picture
what type of input and device are you using? what type of connection? HDMI, Component, AV? DVD player, VCR, Cable/Satellite? Using HDMI will give you the best picture and sound. Best way to test is with a blueray or DVD player using HDMI input. If your picture is still bad, change the main board.
Dec 17, 2008 | Vizio L37 Television
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L37 Television Logo
3,207 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
