Question about Boating
2002 15hp mercurty 2 stroke long shaft need 2 know installation specs 4 propeller depth from top of transom model # 1015211zd
  • 5,537 Answers
I have a 1979 Johnson 15hp Long shaft, and as a single motor just followed the rule of a shortshaft motor for a short transom and a longshaft for a deep transom. You have a little adjustment in the mount clamp. You want enough shaft not to cavitate and want the trim fin below the hull. If this is a kicker motor you want it deep enough for water pickup but less deep for drag on fixed mount.
Posted on Jun 11, 2009
What is the shaft length of my 1998 mercury tracker outboard Serial number OG676641
Measure from the cavitation plate (the one above the prop) to the u bend where the motor hangs on the transom. They are usually considered 15", 20", 25".
Nov 02, 2014 | Boating
Not sure how to remove a driveshaft from a 91 ext. cab mazda truck B2600
Welcome to FIxYa.com
REMOVAL AND INSTALLATION
Remove in the order shown in the figure. Install in the reverse order of removal.
I Image
1. Nut
2. Lock washer
3. Bolt
4. Nut
5. Nut
6. Lock washer
7. Bolt
8. Nut
9. Washer
lo. Nut
11. Lock washer
12. Bolt
13. Rear propeller shaft
Propeller shaft (4x2)
Before removing the propeller shaft, mark the flanges for correct installation.
Propeller shaft (4x4)
Before removing the propeller shaft mark on the front, and rear side flanges for correct
installation.
(4x2 Model)
When the propeller shaft is removed from the extension housing, immediately install the
SST into the extension housing to prevent oil leakage
B2200: 490259440
B2600i: 49 5120 440
1m a
Propeller shaft
1. Align the marks. And install the rear propeller shaft.
Tightening torque: 49-59 N.m (5.0-6.0 m-kg, 36-43 ft-lb)
2. Install the center bearing support assembly.
Tightening torque: 36-53 N.m 3.7-5.4 m-kg, 27-39 ft-lb)
3. Align the marks, and install the front propeller shaft.
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 05, 2010 | 1988 Mazda B2600 Cab Plus
Self-propelled mower started smoking and it was running kinda rough. Then, it started smoking more and more while the motor slowed more and more with the increasing amount of smoking until it died. It will...
not if is a 4 stroke engine not being bothered to include engine make , model year etc makes answering accurately.
you could even say the color of the smoke
so here is a generic answer ( 4 stroke )
it indicates that there is a problem in the needle and seat and there is no fuel flow control in the carby
if it is a 2 stroke with a carby --same problem
ordinary engine oil (20w-40) for 4 stroke sump) and special 2 stroke for 2 stroke engine
Nov 16, 2017 | Poulan Pro 22" Self Propelled High Wheel...
Confused a little
A 4 stroke motor does NOT have Oil in the Fuel. There is NO fuel mixture. Just use regular gas. The only place you need oil is in the sump, and regular 20/30 motor oil will be fine.This only needs to be replaced when low on dipstick in crankcase.
Mar 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Speedaire model 3z492 air compressor. The manual is gone and the information plates as well. I need to know if this model is cappable of maintaining 100 psi @ 10cfm? Any ideas?
Here is info I found "Pump:
Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
Nov 08, 2009 | Air Tools & Compressors
Depth/Length Problem
A longer stroke depth (e.g., 1-1/4") is best for faster, more aggressive cuts, while a shorter stroke length (e.g., 3/4") is needed for plunge cuts
Aug 27, 2008 | Makita Reciprocating Saw 2600 Spm, 8 Amp
Faria Depth finder
I've found this manuals in Faria's site:
Depth sounder:
http://faria-instruments.com/site_manuals/IS0091F.pdf
Bombardier Depth Sounder:
http://faria-instruments.com/site_manuals/IS0138_C_digital_depth_sounder_owners_manual.pdf
Depth Sounder, Flushmount:
http://faria-instruments.com/site_manuals/IS0141c.pdf
Depth Sounder, Flush Mounted, Remotely Switched:
http://faria-instruments.com/site_manuals/IS0229_A_Digital_depth_sounder.pdf
there are also other useful manuals in the bottom of the page:
http://www.faria-instruments.com/downloads.php
Jul 14, 2008 | Faria Boating
Boating Logo
176 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
