Question about Pioneer SX-205 Receiver
"muting" shows up the screen and I no longer get volume, can not the muting off as I can not see where I would change that setting.
Pioneer SX205 reciever shows "muting" on the screen. Have not had this show up previously. As a result I can not get any volume since I can not turn it off. ????
    Brigadier General:
  • 8,546 Answers
Are you sure it's not the TV telling you that it's muted? I went down the tubes on that one myself.
The receiver's Mute can be defeated by just rotating the volume knob upward. Ditto with TV's.
Posted on May 19, 2009
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
Why does my pioneer vsx-d557 automatically go into MUTING WHEN I turn it on?
Maybe you have MUTING selected. Turn the volume knob up or toggle the Mute control on the remote.
If it defaults to muting on power up find the manual and search it for a default volume setting.
May 15, 2011 | Pioneer VSX-D557
AVH-P5000DVD Pioneer eject lock ???? I can`t get CD out Thank you in advance
TURN THE UNIT OFF SO THAT ITS IN DEMO MODE OR SHOWS A BLANK SCREEN. THAT PRESS AND HOLD THE EJECT BUTTON AND MUTE/VOLUME BUTTON AT THE SAME TIME. THIS SHOULD TAKE THE EJECT LOCK OFF....
Feb 22, 2010 | Pioneer AVH-P5000DVD Car DVD Player
How do i make my pioneer super tuner 3d 2 unmute? if i try 2 turn the volume up it just keeps sayin mute and i havent been able 2 find a mute button on it any where?
My Pioneer Super Tuner 3 D was working just fine. The face plate was removed by accident while it was operating. Once it was reinstalled the displays all still work but there is no audio any longer.
Sep 25, 2009 | Pioneer Car Audio & Video
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
The mute wont turn on,on the dell inspiron
Have you tried going into the speaker settings? We'll assume with a new PC you have Vista installed, click the speaker icon on the right side of the tray, and selecting "Mixer" will enable access to volume control for the output devices and for applications.
If no speaker icon is visible To check the volume controls in Windows Vista, click Start and then click Control Panel. Choose Hardware And Sound and then click Adjust System Volume under the Sound section. The Volume Mixer window will open, and you should see volume sliders for Device and Applications. Click and drag the sliders to view the volume level percentages. If the speaker icons show a circle with a red slash, click the icon so the speakers are no longer muted.
Furthermore, you’ll want to double-check all of your master volume and mute settings.
Dec 29, 2008 | Dell Inspiron 4000 Notebook
SD-P5191 Pioneer control inputs lock after startup
Pioneer say Main CPU bad. Replace and install capacitors, diodes and shield plate. See SI Bulletins for more info.(SI-a48032-G)
Apr 14, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SX-205 Receiver Logo
677 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
