Question about Sony Playstation 3 (PS3) Console
Cascading white craziness
I have my PS3 hooked up to my insignia 26 inch flat screen hdtv via hdmi cable. it worked fine yesterday but when i went to turn it back on after work, the tv said no signal then froze up completely and started slowly turning bright white from the outside edge in. my bose dvd player works fine and i dont have any other hdmi things to test out the tv. i did take the tv apart a little while ago, cleaned it out and made sure nothing was roasted. i dont really want to dig into my ps3. can someone help me?
  • 4 more comments
  • mefredd May 11, 2009
    Those should be fun to find lol.
  • mefredd May 12, 2009
    ok, i hooked it up to my tv via the old av cable. the tv didnt see the connection and was displaying no signal. dont you have to go into the settings on the ps3 to change it from hdmi to the old av stuff? if so im screwed unless i can find someone with a tv with an hdmi jack...
  • mefredd May 14, 2009
    did that, the tv only works with the hdmi cable when its set to 480p. as soon as i try to put it on 720p it does the "cascading white craziness." im assuming its my tv, since nobody else seems to have this problem with their ps3. the sound works fine and everything its just a lower quality picture than im used to with 720p.
    when i put it on 720p the tv says unknown input timing as well. i guess i shouldn't rule out the ps3 until i find someone with an hdtv to test it out on but like i said, nobody else has this problem. come to think of it, nobody else has this problem with their tv either. could the actual hdmi cord be messed up somehow? i tested as many of the connections on the cord as i could with the equipment i have and as far as i can tell they all are showing minimal resistance.
  • mefredd May 15, 2009
    you would have to see it in order to know exactly what im talking about. and it only does it when i tell the ps3 to use 720p. i'll set it up for 720p and describe what happens later on.
    ok. here's how i have my system set up. i have my ps3 hooked up to my tv (insignia ns-lcd26a) via an hdmi cable. from the tv, i have an optical cable going to my bose 321 receiver. the tv doesnt throw the bose an audio signal anymore. i just noticed that. i tried the optical cable on my older tv and it works fine. the bose works fine too. im pretty sure the insignia is the problem. what do you think?
    President:
  • 2,653 Answers
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
Posted on May 11, 2009
  • RescueTechLA
    RescueTechLA May 12, 2009
    NO, listen to me. While the PS3 is off (red led) hold down the power until you hear the second beep and quickly release.
    That will reset the video display to default (av cables).
  • RescueTechLA
    RescueTechLA May 14, 2009
    It could be the cable, but it's not likely, nonetheless I wouldn't rule it out just yet.
Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Jan 21, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Insignia DVD Player, Insignia TV, HDMI connection doesn't work
well a good hdmi cable should cost you over 100 dollars, so try a new cable. even though it looks like the cable is fine, it can be no good.
Jun 18, 2009 | Insignia LCDTV26 26 in. Television
Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
May 31, 2009 | Insignia LCDTV26 26 in. Television
White screen
I called sanyo ,they had me try this and that and then said a tech guy would call back he did i am taking the tv to a repair shop and it will be fixd under the warranty.
Jan 11, 2009 | Sanyo DP23625 23 in. LCD Television
Insignia 42" black screen and line problem
Insignia and Geek squad has no other solution exvcept 1080i
Dec 26, 2008 | Insignia 42" LCD Flat-Panel HDTV
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Insignia LCD 26 inch
sum tvs cant take it this is a cheaper model try adjust bass and settinsg in the tv suround mode ect 3d mode adjust treble down
Dec 27, 2007 | Insignia IS-LCDTV32 32 in. Television
Sony Playstation 3 (PS3) Console Logo
424 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
