Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 Won't Turn On!
It was working perfectly the other day. Now it won't turn on!!
I've tried disconnecting and reconnecting. I've uninstalled and I have the disk to reinstall, however, it won't reinstall because it doesn't recognize the printer (because it won't turn on). I have no clue! HELP!!!
  • traceyleehir May 11, 2009
    Yeah I've tried plugging it in to a different wall socket and that didn't work either. I'll try to see if it's the power adapter.
    Problem Solver:
  • 6 Answers
The adaptor on this printer is horrible. I own one and i have the same problem. i used a voltage meter and it didnt read. you cant service them, so you'll have to buy a new one
Posted on May 18, 2009
  • 400 Answers
It could be a bad power adapter or even internal power supply.
The only way to test is to use another power adapter from a similar printer and see if it will work.
Test if there is power from that specific wall socket.
It will have to go to an authorised lexmark support center or printer repair shop ,ask for a quote.
Printers are cheap these days and replacing the part usually cost more than buying a new one.
Posted on May 11, 2009
2 Suggested Answers
  • 12 Answers
SOURCE: lexmark X1240: tried to uninstall and reinstall
Please make sure that the printer is actually VISTA compatible (it should say it on the box) If it is compatible then there is a good chance that the drivers need to be updated. (even if you just bought it) Your first option would be to download the driver directly from Lexmark.com (forget the CD that came with it) Your other option is to download the drivers for LEXMARK X1250 (I have tried this many times with other printers and they worked just fine) I have also used these two web sites to download the drivers for other printers and it seems to work ok so far. Here are the links to the X1250 http://driverzone.com/device.php?id=81664 http://www.siliconguide.com/drivers/device/112/ ...Best of luck to you, I hope I was able to help.
Posted on Apr 24, 2010
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
I have a 2004 Silverado 1500. The rear lights won't turn off, pulled all the fuses associated with lights and they still don't turn off. In addition my right turn signal doesn't flash, both the...
Not sure, but I've heard a bad hazard switch can cause strange problems.
Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
Jan 26, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
Can not get the color to work in my lexmark x1240 printer to work? we tried to refill the old cartrage first but it leaked after a couple uses than we bought a new cartrage but it won't work.
Make sure that you are using genuine Lexmark cartridges and not refilled, re-manufactured or clone cartridges from the 3rd parties. Lexmark products work best with original supplies. If you are using genuine cartridges yet the problem persists, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 01, 2011 | Lexmark X1240 All-In-One InkJet Printer
My lexmark x1240 all-in-one will not print. It saves XPS files and when I go to open them it will not open them. I have already installed the XPS reader. Also, when I try to scan, a box pops up saying...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lgJCxt. Select your operating system, download and execute the file.
Try to scan again to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support for additional assistance.
Oct 11, 2011 | Lexmark X1240 All-In-One InkJet Printer
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
Printing problem
how can we print a booklet on this printer
Mar 15, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 all in one
was it a genuine lexmark ink? if not then that is the main reason why it not working
Feb 10, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 will not work with my laptop computers.
try to pritner off then check also check that your cable is proeprly connected reconnect the cable.
Nov 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
591 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
