Question about Car Audio & Video
Aux chord stuck in dash
I have an aux chord stuck in my 2007 sentra and was wondering if anyone knew how to take the dash off. Nothing seems to be working so I was guna just go in and get it myself.
    Scholar:
  • 105 Answers
Http://documents.victorytechnologies.com//documents/product/9039.pdf
Posted on Jul 13, 2009
My iPod won't play threw my car speakers
is it turned up all the wayy on the actual ipod ? you need to make sure the stereo is on either "AUX" or "AUDIO IN" if that is all fine, get a new aux chord
Jan 06, 2014 | Apple iPod touch
My radio on mercedes c230 2006 won't change from aux input mode can anyone help me .?!
only thing i can sugest is disconect the battery let it power down for a few minuets and then reconect should reset its self (should ) hope this helps ivan
Oct 17, 2012 | 2006 Mercedes-Benz C-Class
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
Sylvania 6842pe blew fuse, replaced fuse, and nothing,no lights, noise, nada. replaced power supply board with the chord attattchment and still no power, no lights, and no noise. Was wondering could it be...
Yes,replaced all the boards that related to the power supply.Useally completely dead,it effect all the ICS in the boards,never able to tell which boards.U are not a tv tech.don't do this everyday's will not have skills or any idea which board is dead.
Apr 06, 2010 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Aux input jack on 2007 honda pilot
If you see and AUX button but don't see the jack then its on the back of the head unit. You need to take the dash apart to pull it out to get the aux jack. Search online for instructions.
Feb 18, 2010 | 2007 Honda Pilot
In our 2007 Mazda 3, when you turn the key to aux
Nothing Wrong there its the Interlock Solinoid for the SHIFTER.
Jul 16, 2009 | 2007 Mazda 3
Looking for plug under dash to hook aux trailer brake controler
The connector is located under the dash on the left side of the steering column. Their is a box, remove the cover and starting from the top left the second connector location moving to the right is the one to hook into, make sure that you have the correct wiring harnass adapter for the vehicle, their are two different ones for GM trucks. On the inside of the cover is also a diagram of the lay out of the box.
Apr 22, 2009 | 2007 GMC Sierra 1500
Aux cable stuck in Aux input
needdle nose plyers or you can use a screw just turn and pull
Jan 25, 2009 | 2007 Nissan Sentra 2.0 SL Sedan
Aux cable snapped of inside external Audio port (AUX). an ideas on how to get the piece out? or does anyone now how to take the AUX port out of the console? 2008 crv, center console unit.
I have a 2007 CRV which had the same issue. I fixed this by:
- first removing the AUX port cover by carefully prying it up from both the rear-facing and front-facing edges. Once done, this exposes the AUX port mechanism itself.
- Using some needlenose plyers, I pulled out the AUX port component. It simply slides out.
- The trick now is to PUSH the broken piece out of the inside of the port. To do this, I first removed the "cover" that is covering the end of the port (opposite from the opening to the port). Be very careful with this step as you don't want to break the cover. It's very thin plastic.
- Once this cover is removed, I used a pin to push the piece that was lodged inside back out of the opening.
Reassembly was the opposite of this and was quick.
Hope that helps.
- Dave
Nov 19, 2008 | 2007 Honda CR-V
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
