I have a magnavox dvd/vcr, no manual, want to record a tv program at a later time.I have a magnavox dvd/vcr, no manual, want to record a tv program at a later time.
You can't post conmments that contain an email address.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording the VCR clock / date must be set and not flashing 12:00 then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
this camcorder has a built in rechargeable battery for the memory of the date and time, if you do not use it for more than three months, it will discharge all the way; to recharge, you need to plug camera with ac power for 24 hours and the camera turned off. this should charge the internal battery complete.
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
the time and code is recorded all the time but the only way to put it on the display is to use the remote control. when plyback a tape press the time/code button(i think this is the right name of the button)on the remote. this camcorder has a different way to display the time than other cams and you have to do this every time you play something(feature does not stay on after shutting down the cam or ejecting tape)
What does "having no sound" mean?
- no sound on playing a known good tape?
- no sound after recording?
- no sound when recording if you plug in headphones or into a monitor?
