Question about Steam Fast SF-250 Mouse Vacuum
CAN,T REMEMBER WHERE THE WATER GOES
I LOST MY MANUEL TO MY SF 250 STEAMER AND CAN,T REMEMBER WHERE I PUT THE WATER
Please open the top white lid and unscrew the top black knob with instruction on the back of white lid.
Posted on Jul 04, 2009
I need to know how much water to put in it.
press the helpful button
Fill the provided measurement cup to the maximum fill line with water. In areas with a high mineral concentration in the tap water, we recommend using distilled or demineralized water to prolong the life of the steam cleaner. Using the funnel, pour the contents of the cup into the reservoir.
Top Innovations, Inc.
400 NW Platte Valley Drive
Riverside, Missouri 64150
www.mitcoproducts.com
1-800-711-6617
http://steamerstore.com/steamfast/manuals/SF-250_Manual.doc
Jan 28, 2016 | Steam Fast SF-250 Mouse Vacuum
Why want my quick steamer suck up dirty water?
Check the manual for filters. They are generally small and need to be cleaned after each use. Consumer Care at 1-800-237-7691
Jul 19, 2014 | Bissell 1970-R Carpet Cleaners
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Lost manual
Hi!  You can download the manual from www.bissell.com Click on the Customer Service tab, then in the next window click on the User Guides link on the left hand side of the screen.  You can then enter your model number and all will be revealed. Good luck!  If this is helpful please remember to rate my response.
Feb 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Forgot where to put water and solution lost manual
The water goes into the soft plastic bladder in front and the cleaning solution ges into the hard plastic in the back of the machine.
Feb 24, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Brand new Steamer.. Worked less than a minute and shut off Trying Model sf 465
take it back to the stor where you bought it and get another one or get a refund.
Jan 14, 2009 | Steam Fast SF-465 Canister Vacuum
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Knob
The safety cap (knob) turns counter clockwise to open so you can put water in. Turn clockwise to close after filling.
Aug 03, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Steam Fast SF-250 Mouse Vacuum Logo
157 people viewed this question
Top Steam Fast Vacuums Experts
JoeVacs
Are you a Steam Fast Vacuum Expert? Answer questions, earn points and help others
