Question about Epson Stylus DX4450 All-In-One InkJet Printer
Unable to print, missing print
Despite repeated cleaning the black still does not come out and would appear that the jets could possibly be blocked and need a serious removal and clean. Is there an easy way to do this without getting all messy and if so how without actually physically going out to buy a brand new one.
  • 344 Answers
Have you removed the pull off tape from the top of the cartridge, it lets air in enabling the ink to flow, easy mistake!
Posted on May 27, 2009
The device will miss lines of print when printing a document despite cleaning the cartridges and ensuring all connections are plugged in. Any ideas?
Try this only if nothing else works.
Hold the nozzles of the cartridge in a jet of steam (may be from a kettle). Then hold a soft rubber tube to the nozzles and **** air. This might clear the blocked nozzles.
Best of luck!
Sep 24, 2011 | HP Deskjet D1341 InkJet Printer
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
    Do the following to clean the print head:
    1. Press INK key on the control panel.
    2. Press the DOWN arrow key until CLEANING appears on the LCD.
    3. Press OK.
    4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
    5. Press OK.
    The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
    If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
    Do the following to print a Print Quality Check Sheet:
    1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
    2. Press OK. PRINT QUALITY will appear on the LCD.
    3. Press OK.
    4. Press COLOR START.
    NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
    Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
    Xerox Phaser 8550 is printing green and yellow with some gray color on all the print job, even after I replaced the ink loader, the black color came back but still getting only green and yellow. The ink...
    Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
    If you have loads of missing jets, run a couple of head cleans, if you see improvement, it is worth running some more, if not, try switching off overnight and rebooting next day. If it still won't clear, you may have a faulty printhead.
    If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
    Hope this helps.
    Dec 25, 2010 | Xerox Phaser 8500/DN Printer
    Black printhead has stopped passing ink over small section.
    As you have already try with the new printheads and the issue still persist then the issue is with the printer hardware so the printer has gone defective
    Hardware issue
    Jul 30, 2010 | HP Officejet Pro K5400dtn InkJet Label...
    Doesn't print black text despite full cartridge
    It may be problem in print head or purge unit, bzt first did you try with print head cleaning under printer properties/preferences?Try few times, if not, remove ink crg., remove print head, take lint free clotch and moisture it with destilled water and put the print head on it few minits, then dry it with anoter lint free cloth.Put it back in and repeat the head cleaning and nozzle check.
    If not helpfull replace print head and purge unit with absoerber
    Mar 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
    Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
    Have ou gone into your menus. Into troubleshooting, then image quality.
    You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
    here are some directions, Will forward more
    1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
    2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
    3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
    4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
      WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
    5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
    7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
    To clean the printhead using the basic eliminate light stripes procedure:
    3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
    4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
    5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
      NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
      To clean the printhead using the advanced eliminate light stripes procedure:
    6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
    7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
      NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
    8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
    Feb 05, 2010 | Xerox Phaser 8550DP Printer
    Black will not print despite repeated cleaings.
    i just had a dead brand new printer cartridge. same printer. try a new one and get $$ back
    May 23, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
    I have a Canon Pixma IP 5000 inkjet printer and am using Mac OS 10.3.9. It has 5 ink cartridges: 2 black (3e and 6) and one each yellow, magenta and cyan. I use it all day every day. After printing...
    Thanks for getting back to me.
    Sorry this ain't a solution but it seems to be the only cash-free way to contact you. No problem not solved - though I have tried everything. Dismantled the printer; washed, dried and replaced the waste ink pads; washed the print head; blew compressed air through the print-head sponge; replaced the cartridge 3 times; printed hundreds of test prints. I can't think of anything else to do and so I think the only solution is to replace the printhead (probably not even available) or replace the printer. The latter is looking most likely.
    Feb 10, 2008 | Computers & Internet
    Epson Stylus DX4450 All-In-One InkJet Printer Logo
    117 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
