Question about Pioneer SD-P4691K 50" Rear Projection Television
Tv has stop working. hear the relay tick when pushing power button but no picture or no sound model number sd-p4553 a pioneer projection television
    Problem Solver:
  • 4 Answers
I had the same problem with a tube TV. It is the "vertical output transistor" that do this, not a relay.
Posted on Aug 31, 2009
  • 3 more comments
  • kasydo Sep 15, 2009
    Sorry I wrote "vertical output", it is the "horizontal output" instead.
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
How to remove front screen
The screen comes off from the front. First take off the speaker grill and you can access the frame screws they are right below the screen. This only takes off the frame with the filter. After the screws are out swing the bottom out a bit and lift straight up on the frame then pull it out away from the set. I have found these to be very stubborn somtimes, but you should be able to get the frame to move then work it up and off. I hope this helps you. let me know if you have any more quesitons.
Apr 28, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Pioneer SD-P62A3-K 62" Rear Projection...
Main power light turns on but i have no picture or sound
Take a closer look at the power board fuses. There is a fuse numbered 106 a little ways away from the rest of them. I have this same model and got it working long enough to diagnose a bad flyback transformer by replacing this fuse with one from Radio Shack. At some times, I could put in a new fuse and have the set work for a few weeks. The flyback transformer is available from parts.pioneerelectronics.com for around $60.
Jan 29, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
PIONEER SD-P4553
are the guns aligned properly? and if there is no difference can you use a voltometer to ensure the board isnt blown?
Jun 16, 2008 | Televison & Video
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Picture mode changes to zoom by itself
It sounds like an eeprom issue. But you can try to reset the set. Turn the set off by the main power on the set. wait a minute or two then together push both the main power button and the standby power button. This should resett the tv. If that doesnt work you will need service as the zoom and the various modes are all controled by the eeprom. Only hold the two buttons for a second. sometimes you will hear the crts discharge while resetting.Hope this helps
Jan 03, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer Tv SD-P4553
You have incomplete vertical deflection at bottom of screen. Replace C155(2.2uf@16v) on video/deflection assy. Use part number ACH1131
Feb 03, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
124 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
