Question about KitchenAid KUDR01TJ Dishwasher
KitchenAid KUDR01TJ Dishwasher Cleaning Problem
I recently replaced an old dishwasher with a 2 year old Kitchen Aid dishwasher and having a problem with gritty material on the dishes in the top rack.  We are using liquid soap. I saw mention about using salt in the dishwasher but our area has relatively soft water for pools and hot tubs.  Typically water has to be hardened in our area for proper PH levels.  I do plan on checking the water pressure, however I did not have this problem on my old washer.
  • 833 Answers
Sinder...this sounds more like a water temperature issue than anything else. First, turn on your hot tap. If you can't hold your hand under it after it fully heats (over 125)...you should be okay. If not, raise your water temp or use the sani cycle to raise the temp. Change brands of detergent. Salt...I don't think so. You're using detergent...not soap...which would have been affected. Pressure should not be an issue...once the unit is filled, it makes its own pressure recirculating with the wash pump.
Posted on Dec 08, 2007
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
Model KUDR01TJ wont work no lights on
1) test the fuse blown +c.breaker reset.
2) Test the switch door, if close not will close the startign relay, and will not operate the motor.see the diagram.
May 08, 2012 | KitchenAid Kitchen Aid Dishwasher Part...
When I turn on dishwasher, water not cycling through and cleaning on a kitchen aid dishwasher
you may have a defective water intake valve. common problem
Please give rate/vote on this response thanks
Dec 19, 2010 | KitchenAid KUDR01TJ Dishwasher
What is the value of a 7yr old kitchen aid washer?
depends on your area, probably 50 bucks, you can check on Craigslit.org for other washers and see what they are selling used for
Jun 29, 2010 | KitchenAid KUDR01TJ Dishwasher
TOP SPIN ARM NOT SPINNING TO CLEAN TOP RACK OF MY KITCHEN AID DISHWASHER. IT IS ONLY 1 1/2 YEARS OLD AND MY TOP TACK IS SUDDENLY NOT CLEANING
Hi.
First ensure that the arm is not getting stuck, and check that the orifices are free.
When the top arm is not spinning you may need to replace pump and motor assembly. First it is good looking for blockage in pump hose.
If the appliance is less than two year old, then it may be covered by limited warranty. Call Kitchenaid at the number listed in the owners manual to verify your warranty status.
Regards.
Nov 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Also have no manual for this dishwasher
Hi
Thanks for using FixYa. You can download the user manual for Kitchen Aid Dishwasher KUDR01TJ from the following link---
Kitchen Aid Dishwasher KUDR01TJ User Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 04, 2009 | KitchenAid KUDR01TJ Dishwasher
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
something in the impeller of the pump, most likely.
will be difficult to get to it if that is the issue.
do not run it with the noise, as you could cause more serious damage.
clear the clog if you can. also, with the front plate off, you might be able to start it for a brief moment to try to locate the source underneath.
careful.
good luck
mark
Dec 23, 2007 | KitchenAid KUDR01TJ Dishwasher
KitchenAid KUDR01TJ Dishwasher Logo
183 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
