Question about BenQ FP931 19" LCD Monitor
When i connect an external tv card to my lcd monitor it immediately reads "OUT OF RANGE" can anybody help
    President:
  • 1,383 Answers
Ok
it is screen resolution problem.
when u power up the computer press F key then enter in enable vga mode then change screeen resolution to 1024*768 in display property.
Posted on May 11, 2009
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
Monitor LCD of my sony vaio VGN CS 13 G/Q laptop is running blank. The monitor LCD light does not perform appropriately (its light is off. I can not read the monitor's LCD so I must add/connect external...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Sony Computers & Internet
I recently purchased a GADMEI external TV card. i used a VGA cable to get it run on my monitor. The problem is, i have a DVD player connected and when i turn it on, the screen goes black and says "out of...
It is saying out of range because the video resolution is too high for the monitor to display. What kind of DVD player you are using and how it it connected to the monitor?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br />
Aug 26, 2010 | BenQ E900 19 inch LCD Monitor
Monitor going berserk
This could be due to corrupt display drivers on the notebook or the video card is going to die. Try updating the graphics drivers on the notebook and check for the issue.
If the issue still persists, then to isolate the exact cause of the issue, I recommend you to connect an external monitor to the notebook and check for the issue on it. If external monitor works fine, then the issue with LCD display screen of the notebook. In case, if the issue persists on external monitor then it states that the video card of the notebook is going to die.
To connect an external monitor to the PC, follow the steps listed below:
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
May 28, 2010 | HP Pavilion dv6000z Notebook
When I turn on My HP Laptop the system start booting and all of the lights on the laptop turned on but the screen doesn't display a thing it is always dark could anybody help me... Thanks in advance...
This could be due to presence of static charges or hardware malfunction of video card or defective LCD display screen of your notebook. To isolate this issue, perform the following:
HARD RESET
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists then connect an external monitor to the notebook and check if it works fine. You can follow the steps listed below to connect an external monitor to the notebook.
May 18, 2010 | HP Pavilion dv1000 Notebook
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
Monitor issue
does it work fine on another computer?
Mar 18, 2017 | Samsung SyncMaster 971P LCD Monitor
My Dell Inspiron 1521 stopped working and the screen went blank. I tried to reboot, but no luck. I removed the battery and changed to a 9-cell, but that also does not do anything. I have it plugged into...
It sounds like either the Video Card or the LCD has failed.
Have you tried connecting an external monitor and see if you get any video?
also, try running PSA diagnostics. Hold the Fn Key while pressing power button, to start the diags, see if you get any video. If you get no video after 50 seconds, you should hear a beep, press N and see if a Set of solid color screens comes on the LCD. If it does, then issue is the video card or cable connection. You can try reseating the video cable to the video card (Connection is under keyboard)
Apr 14, 2009 | Dell Inspiron 1521 Laptop
TV TUner external not starting up
Safe mode
Power saving off
restart normally
Jan 30, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Lcd monitor to dvd player
Hi , You need to have external TV tuner card and then you will be able to connect to a DVD.
Jan 11, 2009 | Microtek 815C 18" Flat Panel LCD Monitor
BenQ FP931 19" LCD Monitor Logo
89 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
