Question about EnGenius EOC-3220 (EOC3220)
Data communication problems accross my WLAN Bridge
I have two buildings connected via two EOC3220s. One is set to Bridge, the other to AP, and the AP side has an 8 port ProCurve managed switch with two PCs and a Linksys AP attached. I am having problems syncing hand held devices across this setup if there is data to upload. If there isn't data on the hand held, then it syncs just fine. Any thoughts?
  • 481 Answers
The first step here is to identify exactly what portion of the link is the culprit. Clearly you must have some sort of AP in the remote building for the handheld devices to connect to, since the bridge radio won't perform that function. So I would attach an AP of that type directly to the ProCurve and see if the problem is present or absent when you try to sync devices using that AP without any involvement by the Engenius units at all. If you isolate the behavior to the Engenius units, you may have to play with the Data Rate and Fragment Threshold settings.
Posted on Nov 18, 2009
This AP is in network x.x.102.0, which has it's own DHCP server. Only lan-port and WLAN are used on AP. I need this AP not to have it's own ip-adress, but devices, that connect to it,using WLAN,...
Ideally, there shouldn't be any configuration needed. Access points are transparent and only work as a bridge between wireless and wired network so devices should obtain their IP info from your DHCP server not the access point by default.
If you face problems, then there might be a DHCP server in the access point, disable that.
good luck
Othman
May 20, 2011 | Symbol AP-5131
My X3 will not get connected to WiFi. The AP is listed usable, internet connection is automatic and eventough I force connection (by pressing long the AP identity in saved WLAN networks menu) and the wlan...
Are you positive that the connection is not going through your Wifi??
I have an HTV Evo and when I am connecting to the internet through the Wifi, my 3g will show up regardless.
Thanks
Mar 29, 2011 | Nokia X3 Cell Phone
Wirless connection wont connect to network.
On the WLAN world, exist a encryption key for connection. You will be able to see the "antenna", but until you enter the key you will not be able to access the network or the internet. First, disable the wireless security and try. Once you have verified the connection to internet then you add security. Use WEP.
Jul 06, 2009 | NetGear WG602 802.11g/b Wireless Access...
DLINK DWL-2100AP
check whether DHCP is enable on ur main AP.
Apr 21, 2009 | Computers & Internet
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    Problem using wireless access point to conect desktop PC to WLAN
    I have solved the problem:
    - first, I had to change the management address in CF-WFAP into address that could be recognized by the router (i used 192.168.1.2),
    - DHCP turned off, and set default gateway and DNS to 192.168.1.1. as in router, computer IP was set to 192.168.1.xxx, push "apply", change web address to new one,
    - set AP mode to station-infrastructure, push "apply" buton to restart AP,
    - set security to same security as in router and copy key into proper field, push "apply" again to reset the AP
    - finaly check wireless station around and choose the router (same encription)
    Mar 21, 2009 | Computers & Internet
    Notebook won't connect to network
    1) Verify if Wi-Fi WLAN interface of your notebook is OK.
    1a) Check whether HW switch is ON and the wireless system service is running.
    1b) Switch on the WLAN Access Point (router) SSID broadcasting.
    1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
    2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
    3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
    4) Select your home WLAN SSID in the list and try to connect.
    5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
    6) In success case set the WLAN security.
    Dec 20, 2008 | Computers & Internet
    Wlan dosent connect to net work
    Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
    Sep 26, 2008 | Sony Computers & Internet
    ZyXel P660HW-T1 ... Problem bridging 2 wirless adsl routers
    What do you mean by "wireless bridging"? Does it mean wirelessly connecting both routers? (ex. Zyxel is at location A and Micronet ais at Location B and you'll wirelessly connect them). If this is what you mean, then it might not be possible since those are two different brands and possibility is that they will not work with each other when they're wirelessly connected unless one or both routers have the capability to do so.
    May 04, 2008 | Zyxel Prestige 660HW Wireless Router...
    AP Mode Problems
    Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
    PHASE I
    1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
    (where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
    1. Connect the EOC-3220 to your computer with a null modem serial cable.
    2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
    3. After the HyperTerminal window appears:
    a. Give this new connection a name. Ex: EOC-3220.
    b. Select correct COM port. Ex:COM1.
    c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
    4. Wait until the "#" is displayed in the HyperTerminal window.
    5. Type "flash reset", then hit enter.
    6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
    Phase II
    1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
    2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
    3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
    4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
    5) And lastly change the default user and password of your AP.
    Good Luck
    Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
    EnGenius EOC-3220 (EOC3220) Logo
    164 people viewed this question
    Top EnGenius Computers & Internet Experts
    Michael Vincent Cruz
    Karen Gibson
    Level 1 Expert
    Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
