Question about Astra Mega II Espresso Machine
Water flow We purchased a used astra machine and it is automatic, but it doesn't seem to pump enough water for a shot of espresso. How can we adjust the amount?
  • 1 more comment
  • Anonymous Jan 11, 2008
    water flow
  • Architect70 Aug 08, 2008
    Water just trickles out and then stops. Checked all water supply valves and they are on and working... Water isn't very hot either...
  • aslan77 May 11, 2010
    Are you saying that the water flowing through the group head screen isn't coming out with enough volume, or that it isn't on long enough to pull a whole shot?
    Problem Solver:
  • 7 Answers
You will have to adjust your shot timing, and possibly your grind. To program the shot timing, hold the Brew Stop button until all of the brew lights come on; That means all of the buttons are ready to program. Next, pull some grind for your portafilter and push the button you want to program. For a single, you want to pull a 1 oz shot in about 15-20 seconds; longer for a double. When you push the button, the shot will start to pull; when the shot is complete, push the button again to set it. Then do the same for the next button. Each group needs to be programed separately. Holding the the Brew Stop button again will turn out the remaining lights and save your programming to that point. As to the grind, you want to have the grind fine enough to give you a quality shot in the right amount of time. Good Luck!
Posted on Aug 29, 2009
The esspresso shots are watery
You need to adjust the grinder to finer and the amount of coffee grounds.
Dec 26, 2010 | Astra 2000 Espresso & Coffee Maker
Faema due smart two group espresso machine, I am having inconsistant shots. this is an automatic machine and I have reprogrammed the shots however it is still being inconsistant as far as flow through the...
when you open the hot water valve all the way does the pump come one? You might have a newer version that has a mix valve. This allows a controlled amount of cold water to be mixed in with the boiling water from the boiler. If so you would find an adjustment (usually just a black knob) that is next to that valve. If the final amount of water for the espresso is fluctuating then you have a problem with your flow meters (dirty impellors or bad field sensors). If you notice a different in the amount of water flowing from one group to the next then something is clogging up the jets or group heads. It could also be a sign of your dispersion screens going bad or other stuff. Have you had it maintenance within the last six months. I have the manual for that machine if you need a copy.
Good Luck, mikey@espressomachineexperts.com
Oct 22, 2010 | Bunn CDBCF 15 APS Coffee Maker
I have an Astra Mega I single group espresso machine 110v. I seem to not be getting enough water through the portafilter and it is all clean.
Remove portafilter, shower and screw and run the head. Did you get a nice steady flow or a weak drip. If a weak drip then the solenoid or the metering jet on the head is blocked and needs to be cleaned. If you get a nice flow the adjust the grind on the coffee to coarser.
Jan 15, 2010 | Astoria Divina SAE-1 Espresso Machine
WEAK espresso from Saeco Vienna!
Well, when you set it that low it allows the water to pass very quickly and if the water passes very quickly there may not be sufficient time to absorb the coffee; hence weak coffee. The setting should be reset to the middle, at 10, and tried again. Then, if you want to change it move it only one or two numbers for enough cups to see if there is any change before you move it a large number. Going higher or lower makes it pass more or less quickly with results accordingly.
You may also have the dose set too low and you may want to set it higher increasing the amount of coffee in each dose.
Then again, since it was used, you don't know if the machine was taken apart by someone who reinstalled the machine with the dials you are using out of whack with where they should be set.
George W Conrad.
Apr 02, 2009 | Saeco Vienna Espresso Machine
Makes three shots and that's it.
Is there a bypass setup on the pump, or have you checked the capacitor on the machine.
Mar 26, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Automatic astra II pulls a few great shots then error light on
The error light usually comes on when there is no water flow through the group after about 5 - 10 seconds, indicating a clog of some sort. The fact that it happens after two shots, however could indicate an issue with the processor. The problem with the steam wand could also point to a clog situation, especially in the other wand is working. First, try running shots through the problem group with no grounds at all in the portafilter; Say five or six shots if you can to see if you get the error light. Look at the water flow in the process: The water should just pour out of the portafilter. If the water is running freely and you still get the error light, you are probably looking at a processor/sensor problem. If not, it may just be a restriction. Remove the screw from the middle of the group head (the diffuser), and remove the screen and the brass plate and check them for clogging. You really want to wait until the machine is cold before you do so as the parts will be extremely hot. As for the wand, try removing it, and check it for obstruction.
Nov 24, 2008 | Astra Mega II Espresso Machine
Espresso extraction time
You will need to reprogram the computer. To do this, it is relatively simple. take your grounds and tamp into your portafilter (I usually start with a double). make sure that you tamp it correctly.
Then, hold down the start/stop button until you see the lights flashing on the panel (if you want to program both groupheads at the same time, then hit the start/stop button on the other side as well.) Then with your portafilter inserted in the grouphead, hit the button that you would like to represent your double shot. you should see a water stream about the width of a cooked piece of spaghetti. After around 18 seconds to 22 seconds, you should have your shot levels filled. then hit the button that represents your 'double' shot to stop it. then hit the start/stop button. You will see the start stop button flash a couple times and then turn off.
That should do it. remember, that the preferred timeframe for a shot of espresso is 18-22 seconds. Your setting on the coffee grinder would then need to be set to make sure your getting a full shot in that amount of time.
Good luck
Dec 09, 2007 | Astra Mega II Espresso Machine
Astra Mega II Espresso Machine Logo
342 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
