Question about Zanussi Washing Machines
Zanussi Jet System washing machine, FJDR 1466 W, E10 error.
Hi, I have a Zanussi Jet System washing machine, FJDR 1466 W. The error code E10 keeps bleeping throughout the cycle primarily during water filling operations. I press 'start' and the machine continues but the overall wash takes much longer than indicated. The powder is not flushing out of the tray properly.I have checked on the internet etc, checked my hoses (ok) & no blockages but to no avail. I have read that maybe an inlet valve needs to be replaced. Please could anyone advise what's wrong and if I can fix it myself? Any visual diagrams would be gratefully received. Kind Regards, Siobhan.
2 Suggested Answers
SOURCE: can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
Posted on Dec 11, 2009
Zanussi jet system washer error code 247.whats this mean?
Nothing. It is not error code, maybe is time washing for example: 2 hours and 47 minutes. All errors code starts with letter "E" and two numbers or only with two numbers.
Dado
Dec 12, 2016 | Zanussi Washing Machines
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
Can anyone help ive got a zanussi FJDR 1466 W. e91
Nov 02, 2009 | Zanussi ZWF1430W Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
Washing Machines Logo
293 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
