Question about Frigidaire GLTF2940ES Front Load Washer
OCCASIONALLY, IT WOULDN'T RINSE. WHEN RESTARTED,
OCCASIONALLY, IT WOULDN'T RINSE. WHEN RESTARTED, IT WOULD FUNCTION FINE. YESTERDAY, IT WOULDN'T RINSE. I TRIED DIFFERENT SETTINGS. IT WON'T EVEN FILL WITH WATER. IT JUST SITS AND GROWLS UNTIL IT FAULTS OUT. THE DISPLAY READS "ERROR 20".
    Sergeant:
    Champion:
  • 219 Answers
You may have a fauly door lock switch.
Posted on May 11, 2009
I have a Kenmore 80 Series Washer (Model # 20802990) and it was working fine yesterday, and today it will go through the wash, fill up and go partway through the rinse cycle and then stops. It wont drain...
the lid switch is broken this video will show you exactly how to replace it....
http://youtu.be/MFsvLiuTniU
the part#for the switch is 3949238 you can order it by going to searspartsdirect.com or look in your local phone book and find a parts dist. in your area
Jul 20, 2011 | Kenmore 24032\24036 Top Load Washer
My 2000 cirrus rattled for a few days then yesterday rattled loudly and died. I restarted it but then it died again immediately and would not start at all. Took it into the chrysler garage and they tell...
How can someone make that judgement for
you,it is your money
I would fix it myself
I certainly wouldn't be at any dealer
after the warrantee ran out
Jun 17, 2011 | 2000 Chrysler Cirrus
Occasionally my 2002 Highlander won't start without a jump. The first time, there was no power to anything, but after wiggling the cables, it started. I cleaned the terminals and load tested the...
Check your starter solenoid. Sometimes the wires loosen, or the solenoid just goes bad. Check to make sure all wires are firmly attached. Hope this helps.
Jun 15, 2011 | 2002 Toyota Highlander
Rinse cycle doesn't pump out
Sounds like the drain pump needs replacing.
Have a serviceman check to prove this is the problem.
Jul 29, 2009 | Dishwashers
TCS ans ABS and Brake light on 2005 hyundai santa fe
There is a senor that is in the caliper they are pricey and annoying a way to try to see if its it make a soltuion of salt water, heavy salt soak the whole caliper reall good i mean real good with start the veh. back up and down the drive way then rinse it off throughly and see what thew the lights do, do this f or ll sides, make sure you throughly rinse after and dont let the salt water saty on for mor e than 10 mins. But this will fluse the senosr and clean it...Sometime resets them,,,,Sounds crazy but it works if that is the problem. Try this and let me know fro m there
May 18, 2009 | 2002 Hyundai Santa Fe
Cold water only works on rinse cylce not was
post model number in problem description
Apr 04, 2009 | Maytag Washing Machines
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
