Question about Liebert (PS1440RT2230) UPS System
UPS only developing 39 VAC
Liebert PS1440 UPS only developing 39 VAC output
    New Friend:
  • 25 Answers
Did you get this problem fized?
Posted on Jul 11, 2009
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
After battery is discharge because power failure, ups is not automatically working even there is power supply
Check on the back of the UPS to see if the input circuit breaker has tripped. Are you getting any lights on the front LED's? Also disconnect all loads and ensure nothing is plugged into the output receptacles. Also open UPS up and ensure the input fuse is not blown. You will need a meter to check this out.
Oct 11, 2011 | Liebert UPStation GXT2000RT-120...
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
Has a alarm "UPS OUTPUT OFF" model GXT2-6000RT208
there is alot of possible reasons. Try and press the on button for 3 seconds or call me at Gruber Power Services for free tech. support. 800-658-5883 x256 ask for Eric
Aug 10, 2011 | Liebert GXT26000RT208 (GXT26000RT208BN)...
No output voltage, the ups does not power on, the battery does not support for a long time
Some UPS's will not provide output if the battery inside of it is bad. This is so you will not have a false sense of protection. Always have a known good battery to test any UPS.
Oct 18, 2010 | Liebert Computers & Internet
How many systems support for 1 KV UPS
1 KVA UPS will provide you good back up with 2 pcs simultaneously without any power fluctuations.
May 24, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
Need to monitor status of Liebert 150 KVA UPS
Try to find your manual here in this site. Choose your Product Category, Product Application, Application Type and Specific Product. After that you can download the manual. Hope this helps. "http://www.liebert.com/servicesupport_pages/ProductDocumentSelector.asp"
Jun 03, 2009 | Liebert Computers & Internet
Need repair manual for Liebert UPStation GXT1500RT
Hello gypsy6767, I spent 10 years as a Liebert Rep here in the Phoenix, Az. market! Here is a link to the Liebert GXT User's Manual - http://www.liebert.com/common/ViewDocument.aspx?id=1199
I hope this helps,
map6260
Mar 12, 2009 | Liebert UPStation GXT1500RT...
Liebert UPS fan work fast even when off
this system is opperated by fieldeffect transistors it may be obviouse that 1 or 2 component especially the FET may be sort circuting
Jan 19, 2008 | Liebert (PS2200RT2230) UPS System
Liebert Power Sure UPS
the battery is bad, you will need to replace the battery or the whole unit. you can find batteries on ebay. just source the model number. also depends on the size of the unit. you may need to just replace it...just a better value to do it that way.
good luck
K.
Jan 14, 2008 | Liebert PowerSure PSI UPS System
Liebert (PS1440RT2230) UPS System Logo
54 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Marco De La Fuente...
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
