Question about Acer Aspire 3000 Notebook
CD Writer not writing/reading
My Acer 3000 CD writer doesn't seem to write or read. Could it be a conflict with the Windows XP and NTI Back up loaded software? Both were on the PC when I purchased it new. Neither has been amended; CD has always been a bit tempramental. Any suggestions?
    Scholar:
  • 69 Answers
When you open "My Computer" or Windows Explorer, can you see the drive? If you can see the drive then there's no conflict.
If you can't see the drive, then either it's disconnected, disabled, or bad.
If you can see the drive, the try downloading software to remove Malware from your system - quite of such software will shut down your CD drives. Otherwise, replace the drive if it's replacable, or get an external drive.
Posted on May 25, 2009
LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
May 04, 2010 | LG GH22LS50 DVD-RAM Burner
I am trying to burn a DVD that is 1 hour and 49 minutes long and it will not burn correctly. On a DVD-RW it only recorded just a small amount at the beginning and also had music in the background. I tried...
Make sure you treat your blank CD-R's with respect.
Scratches or dust may cause write errors! Handle the disc carefully when transferring it to the CD drive! DMA & Auto Insert Notification (AIN)
DMA does not allow the CPU to have full control of the Writer, thus causing Lock-ups and Buffer Under Run Errors. Auto Insert Notification causes a CD Disc to autorun. This causes problems when you use the Writer as the Reader & as the Writer. Rule of Thumb, always uncheck Auto Insert Notification and DMA To disable AIN with MP3 CD Burner, simply go into the Preferences and uncheck 7q Auto Insert Notification7q You will have to reboot. Media
Non-Branded media/No Name media is generally lower quality and are commonly referred to as Seconds or "B" grade. This type of media will cause errors when writing, especially on the outer part of the disc (500 MB or better) where the dye becomes thinner. This can also cause playback problems. Close all Programs prior to Writing
Using CTRL+ALT+DEL will allow you to access the Close Program window. The only programs that should be running while Writing are EXPLORER, NTI Software & SYSTRAY if you must. TSRs will steal CPU time away from the Writer, which may cause Lock-ups and Buffer Under Run errors. Screen Savers & Virus Checkers
These programs should have been closed in step #3. Screen Savers, Virus Checkers, Crash Guards and Uninstallers will intercept commands and steal CPU time away from the Writer, which may cause Lock-ups and Buffer Under Run errors. (Screen savers are automatically disabled during a burn with CD Burner.) Power Management
Power management is a program that shuts down the Hard Drive and turns off the computer's monitor to save energy. These actions may cause Lock-ups and Buffer Under Run errors if they happen during the writing process. It is highly recommended to turn off Power Management in both the Control panel and in the computer's BIOS. (Power management is automatically disabled during a burn with CD Burner.) Defragging the Hard Drive
It is recommended to Defrag the Hard Drive prior to writing a CD. If the Hard Drive is fragmented, it will cause the Hard Drive's access time to diminish. A slower access time may cause Buffer Under Run errors due to the extra time it takes the Hard Drive to send the data to the Writer. Disc Compression
Compressed Hard Drives (Double Spaced) will cause the access time to diminish. A slower access time may cause Buffer Under Run errors due to the extra time it takes to uncompress the data and send it to the Writer. Latest Writing Software
A lot of little problems are solved by upgrading to the latest Writing software. Updates have patches to fix bugs and known writing problems. It is highly recommended to always use the latest software available. Viruses
There is always a possibility of a Virus being on your system causing weird problems. Running a Virus scan on the computer will verify a clean system. Make sure you have the most current virus definitions installed in your Virus program. In addition, don't forget to turn off the Virus program prior to writing.
Reboot / Restart
If the computer has been on for a while, reboot (restart) the computer prior to writing. Multiple Writing Software Programs
Having multiple writing software on your systems (Adaptec, Nero, Prassi, Veritas, etc.) are known to cause system lock-ups. This is due to each writing software modifying the same files "winaspi.dll, wnaspi32.dll, and apix.vxd" and then not being compatible with each other. This normally is the case on older operating systems (Windows 95/98/NT). In newer operating systems, writing software's have their own ASPI layer, however more than two writing software are also know to cause lock-ups. Log file says "*** Found DLL's for WinOnCD!!!"
There are known conflicts between WinOnCD and our MP3 CD Burner software on some Windows installations. If you are having burning problems, and your log file says "*** Found DLL's for WinOnCD!!!" you may choose to uninstall WinOnCD via the Add/Remove Control panel. Alternatively, you can go into your "WINDOWS\SYSTEM\IOSUBSYS" directory and rename the following files:
  • from C2APIX.VXD - to C2APIX.BAK
  • from C2REC.VXD - to C2REC.BAK
Restart Windows and try the software again. If it doesn't make a difference and you want to continue using WinOnCD, you should restore the 2 files to their original names. Bus Mastering Driver Conflicts
They cause intermittent lock-ups and static on audio files. Most Bus Mastering drivers are not compliant with any Writer, Tape Back-up, etc. Uninstalling the Bus Mastering drivers will fix a lot of writing problems. (Manufactures: ALI, VIA, SYS, Intel, CMD, OPTI, TYAN, AMD) This is only for the technically experienced. Most people reading this should have an experienced Windows technician check this out. More on this in the McFadden FAQ . Latest Firmware
A lot of little problems are solved by Flashing the Writer to the latest firmware available. Updated Firmware has patches to fix bugs and known writing problems. It is highly recommended to always use the latest Firmware available. Dual Boot Systems
Multiple Operating Systems are known problems with Writers. Trying the Writer on a Single Operating System is an easy way to confirm this problem. We do not recommend or support Dual Boot/Multiple Operating Systems due to known problems. CD-ROM Dos Drivers
Computers that load the CD-ROM DOS driver (16 bit) in the Config.sys file and the Microsoft extensions (MSCDEX.EXE) in the Autoexec.bat file, may/will cause conflicts with the Windows drivers. It is highly recommended to remove these lines from the above-mentioned files. Symptoms would include Lock-ups, Buffer Underruns, Intermittent errors, and Yellow Exclamation points on the Primary or Secondary IDE ports. Startup programs are slowing down computer
The solution is to disable startup programs. Warning! If you aren't sure what you are doing, proceed with caution! Click Window's Start button, followed by clicking "Run". Type ""msconfig"" without the quotes followed by clicking "OK". Click on the "General" tab, followed by un-checking "Load Startup Group Items". Click "Apply" and then "OK". You will need to restart. (Note that some startup items might be necessary to run your computer peripherals. This is a good test to see if a start up program is slowing your computer down, though.) If you need to re-enable Startup programs, repeat the instruction above, except make sure to check the "Load Startup Group Items"
Nov 19, 2009 | Computers & Internet
Problen in reading a cd rom
Dir Friend problm in you dvd writer
1.remove the dvd wirter and change optical lance in dvd drive ....................1000% garenty you dvd driver is working .......fine All midea like cd ,dvd
www.compudesk.in problem is not resolve send me your quiry
Mar 24, 2009 | Computers & Internet
Dvd rome is not write the cd or dvd
you have dvd rom
it can only for read cd and dvd
dvd combo
it can only read cd
write cd
read dvd
dvd writer
it can read/write cd and dvd
Jan 24, 2009 | Lenovo 3000 Y410 Notebook
Computer:Acer 3053WXM1 notebook-serial number:64603188225 When I try to write to CD the CD Writing Wizard is telling me-NO DISK IN DRIVE E even though there is a CD in the drive.Also it will not read...
Please update drivers for your CD/DVD writer from Acer website. that will solve the problem. Additionally buy a Good qyality CD/DVd lens cleaner and use it to clean the lens of the CD/DVD writer
Dec 17, 2008 | Computers & Internet
DVD Writer not burning
I have come across this quiet abit. U could try updating the firmware but I would say that the lazer is past its best. I presum it still read the cds fine? I would suggest getting another drive if firmware update doesnt work
Oct 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cd burning drive
ARE YOU SURE THATS A CD WRITER NOT JUST A CD ROM. IF ITS A CD WRITER AND YOU ARE USING THE OS AS WINDOWS XP....JUST TRY SENDING THE FILE DIRECTLY TO THE BLANK CD IN THE DRIVE...IF IT BURNS THE CD WRITER IS OK AND THE APPLICATION (NERO OR WATEVER) YOU ARE USING TO BURN THE CD REQUIRES TO BE REINSTALLED
Apr 21, 2008 | Compaq Presario 5000 PC Desktop
Regarding the Dvd Writer Problem--Urgent
Ok.I got your point.Now I want you to try this first
1.Go up to device Manager
2.Under CDROM/DVD remove your DVD(Uninstall it)
3.Restart your Windows
4.after login your windows,wait for a minute,Windows should be able to detect your DVD back
5.Check your DVD in Device Manager again that its been detected back
6.Now try your DVD again.
Goodluck...takecare
Apr 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
Optorite DD0401 DVD +/- RW
Right click My computer>Explore, and see if your dvd writer is showing as a DVD RW drive and not a CD Drive, then come back
Nov 14, 2006 | Optorite (dd0401) DVD±RW Burner
Acer Aspire 3000 Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
