Question about Techko SH1524CP Shredder
Shredder stops shredding, you have to turn it off and on,
Shredder royal PX 110MX
This shredder will work for a while, then it will just stop, sometimes you can turn it off and on and let it sit a while , It might restart at this point or not.
It is frustrating when you are trying to shred a small stack of documents.
  • 5,568 Answers
If I had designed a shredder, I would equip it with a circuit or device that would detect overloads (too much stock to shred) with either an overcurrent detector or a thermal shutoff so it's likely that one of these two methods is used in yours and if you are following the guidelines as to the maximum number of sheets, then this circuit is faulty and shutting the motor down too early.
Posted on May 11, 2009
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
My Royal PX 100MX is not working (have not shredded enough for first dump) container is 1/2 full of shreddings. Is there a reset to the motor some where?
You say its not working??? Does it even run in reverse??? Did you have it jammed up???
A little unusual for one just to stop working for no reason.
If it was jammed up you may have "pooched" the pcb inside. Contact Royal at 1-800-524-0799 for parts assistance.
Dec 16, 2010 | Royal PX1000MX Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
Techko SH1524CP Shredder Logo
210 people viewed this question
Top Techko Office Equipment & Supplies Experts
Randy Schumann
Randy Schumann
casper muchato
Level 1 Expert
Tom Chichester
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
