Question about Dryers
Dryer will no longer turn
Dryer is no longer turning
    Problem Solver:
  • 14 Answers
Check to make sure if it has a belt that it hasnt broken.it may also be the motor
Posted on May 15, 2009
My dryer wont start any longer...it makes a buzzing sound but no start. Any suggestions?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Frigidaire FER311FS Electric Dryer
I own a Kenmore 796.8044 steam dryer. It is less than one year old and the drum will no longer turn. I suspect either the belt has slipped off or has broken. Is this a common problem?
heatman101
Jul 29, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
My dryer takes longer to dry my clothes than normal and after 2 drying cycles it hesitates to turn on or won't turn on at all for about 20 minutes, then it will turn on.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 23, 2011 | LG DLE2514 Electric Dryer
The dryer no longer heats up and the timer no longer turns the dryer off .. .... the dryer works fine otherwise ... it is a gas dryer.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 29, 2010 | Dryers
The start button no longer works. When you push it in it sticks and the dryuer will not turn on.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | GE DCSR483EA Electric Dryer
My dryer drum will no longer turn easily...and dryer won't start.
sounds like the motor is going bad,did you remove the top to see if the belt broke or if it jumped the track?mike
Feb 19, 2010 | Kenmore 62802 Electric Dryer
Kenmore 70 series dryer doesn't turn
your dryer motor has just gone bad,it is no longer strong enough to turn over-sorry-mike
May 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Aug 29, 2008 | Kenmore 60172 Electric Commercial Dryer
My dryer drum is no longer turning when I press start.
When you turn it on, can your still hear the motor running but the drum doesn't spin? If so, yes, the belt could have broken or slipped off the pulley.
With my dryer, putting in a pair of shoes often makes it turn off. I hear it tumble for a while and then and then I hear a squeal and then the dryer turns off.
I have seen a device that can be put inside a dryer and adjusted to fit tight between the diameter of the drum and will allow you to put shoes on it. This solves the CLUMP - CLUMP - CLUMP issue.
If you don't hear the motor, its possible there is a blown fuse. have you checked your breaker panel too?
Good luck,
- Jim
Jul 15, 2008 | Danby DCD5505W Electric Dryer
Dryers Logo
Top Dryers Experts
