Question about Cakewalk SONAR 4 Producer Edition for PC
Timing after recording. and midi composing
Am facing the problem in cakewalk soner pedition-3.the problem is abt the recording.after what i have recorded is not in the proper timing.when i here the wave after recording.another thing is that the waves are not matching when i import some wave from out source even i have assighned the actual tempo.plz can u give me any solution for that n i will be gladfull to ya.
Thanks
Raj
  • 39 Answers
May I suggest you try to adjust your audio settings inside Sonar. Also it is a good idea to always keep your C drive well defragmented. I once had this problem using Sonar LE and the only way I got rid of it was after formatting my C drive and reinstalling the drivers and Sonar again. After that the problem came back and then I upgraded from the SB Live to Audigy SE.
Make sure you also have lots of free space on your C drive and have a decnt amount of ram.
Posted on May 19, 2009
Tascam 2488 neo mmc control
That seems to be in the midi time sync functions. In cakewalk under options find the midi settings and choose midi device. All of you clock and sync settings should be there. Also I think under the audio menu there are settings for folders and I think a tab for sync is there as well. I use Sonar, which is an upgrade of cakewalk but used cakewalk for a long time. I have it on another computer and will look later to see if I am forgetting something or remembered it wrong and let you know.
Mar 14, 2013 | Tascam 2488NEO 24 TRACK RECORDING...
Edirol pcr 50 dont know how to work
Dont forget that the PCR50 is a Midi controller and as such has no "sound" of its own. You must have Midi compatible player or composer type software (like Reason, Cakewalk, Sonic, etc) to link up to the PCR50 to get any sound.
May 12, 2010 | Edirol PCR-50 Keyboard
MIDI problem
sounds like you need to print the output from your midi in audio form to mix with the existing audio. There should be some kind of audio bounce feature. try that.
May 07, 2010 | Cakewalk Music Creator 2 for PC
How do i hook it up can it be used threw the usb or does it have to be connected with midi
As far as I can tell it will connect with USB as it has a USB connection.
Nov 17, 2009 | Edirol PCR-50 Keyboard
Stuttering during audio playback in Sonar
The stuttering is caused by excessive CPU usage, in other words: you have too little CPU power to play the file with the inserted synth smoothly. You could try inserting a different synth or play with the rendering-options of the synth (like disabling aliasing, etc.) or increase the audio buffer size (under audio options ?), but the only longterm solution is upgrading to a much faster computer.
Even when you find some tweak which lets you play the file (just) smoothly, adding another effect or synth is likely to cause it to stutter again, since your computer doesn't meet the official (!) minimal requirements for running Cakewalk Sonar 6, which is at least a Pentium 4 1.3GHz computer (and you have a 1.0GHz computer).
I would recommend upgrading your computer to something which at least meets the "recommend requirements" of Cakewalk Sonar 6, which is a Pentium 4 2.8GHz or newer (like any Intel Core 2 system), when you're serious about composing music.
Aug 12, 2009 | Cakewalk SONAR Power Studio 660 Full...
MY MIDI NOR SIGMA TEL HAS SOUND OUTPUT
Signma Tel is notoriously bad for recording. It often doesn't work. But try changing your driver mode and then running the wave profiler. restart everything and make sure that your sound card is chosen under playback timing master and recordi timing master so that it is the chosen card. UNLESS- the keyboard has it's own sound card or interface built in, then its a different thing. You'll have to find out what kind of drivers THAT card uses and do same thing choosing that as card with correct drivers. Also check MIDI devices and make sure its in there. U might wanna email tech cuz this is a little more complicated than a regular set up
Feb 17, 2009 | Cakewalk Music Creator 4
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Audio Popping
Looks like a nice system. I might have to get my wife one of these.
I couldn't find any support on cakewalk.com about it. In fact the pictures wern't even posted up anymore on the product.
I have one suggestion. Is this unit plugged into a surge protector? You could be getting something filtering in through you power like another electrical appliance. You might want to try a stronger surge protector to filter it out.
Jul 17, 2008 | Cakewalk Power Studio 660 Firewire Audio...
Scratchy sound
Yeah, many others have the same problem try reading the solution to one of the other ones of these with the same device. I'll try and find it to put the link in to the answer.
Feb 27, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Hi need sound
Certain early models of the Sound Blaster cannot do both MIDI input and wave (audio) output at the same time. Thus, if you've selected "Creative Labs" as a MIDI In device in Cakewalk’s Options | MIDI Devices dialog, wave audio output won't work. Note that MIDI output will work fine along with wave audio output: you can select Creative Labs from the list of MIDI Out devices. The problem occurs only when you've selected the Creative Labs MIDI In device.
Hope that helps!
Dec 08, 2007 | Cakewalk Guitar Tracks Pro 2 Classic
Cakewalk SONAR 4 Producer Edition for PC Logo
109 people viewed this question
Top Cakewalk Computers & Internet Experts
Dan Shibata
Dan Shibata
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
