Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry curve scroll button sticking
I have a Blackberry Curve 8310. The central scroll button will not scroll downwards although it will scroll up and left and right. It feels as if it is sticking somehow on the downward movement.
Is there a way to reset this function or fix it? Or a way to take the button off and put it back?
I had a similar problem, and the only solution is to change the trackball which cost between $5 & $10 dollars on e-bay. An easy and cheap fix, it comes with the tool to replace the assembly. A kid can do the job
Posted on May 12, 2009
I realize this is many months later than you asked for help, but since I just now read it I thought I'd let you know I had the same trouble all day today. It is likely there is dirt under your trackball. Push down on it and try to move it downwards as you are pushing. It may dislodge the dust/dirt underneath. An alternative I used (when the solution above didn't work for me) was to spray a VERY SMALL amount of window cleaner on a paper towel. Wipe the moist paper towel on the trackball, moving it in all directions. That should dislodge the dirt and the trackball should move in all directions. Worked for me. Caution: don't use too much cleaner - don't get the paper towel dripping wet.
Posted on Sep 24, 2009
How to turn speaker phone on on a blackberry 8330 ?
newer blackberries turn speaker phone on by when your in a call pressing the blackberry button next to the control pad to bring up options and then scrolling to find speaker phone on this may work
Sep 21, 2013 | RIM Blackberry Curve 8300/8310/8320/8330...
What is the code to unlock the blackberry 8310 curve
Do you need to unlock your Blackberry Curve 8310 from network lock?Blackberry has 10 unlocking tries..So you have 4 remaining unlocking tries.You can get the unlock code from the site
Classicunlocking.com for Blackberry Curve 8310 and unlock it easily using the unlocking instructions below...
Blackberry Curve 8310 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Blackberry Curve 8310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
Oct 26, 2012 | RIM BlackBerry 8700c Cellular Phone
I cannot click using my trackball (AT&T Blackberry Curve 8310).I can scroll up and down but when i go to click on any applications, a menu comes up just as if the menu button to the left of the...
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
Oct 19, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Silence the keypad on a blackberry curve?
1. Options
2. Screen/ Keyboard
3. Scroll down to key tone
4. Change it for "on" to "off"
Oct 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
Scroll wheel on 8310 Curve does not allow scrolling down
I can repair this problem. If you would like to inquire about services, please send an email to IGcomputerservices@gmail.com
Jul 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
May 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
What is the return key on the blackberry curve
it is to the right of the keypad with a downward arrow bending and pointing to the left. it is to the right of the $ key and right below the DEL key. hope this helps
Jan 17, 2009 | RIM BlackBerry Curve 8310 Smartphone
I need help gettin my blackberry curve 8310 unlocked
unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry curve 8310 Unlock Code. Buy your unlock code from third party.
Nov 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Need Help
You will need to use the Desktop Manager in order to do this. You can download it from here:
http://na.blackberry.com/eng/services/desktop/
Once installed, do the following (instructions are based off of 4.6 version of Desktop Manager):
  1. Connect your BlackBerry to your computer via USB and open the Desktop Manager.
  2. Open the Backup and Restore section.
  3. Click on the Advanced button in the Advanced section.On the left-hand side the list of the device databases will show.
  4. Scroll down and select Address Book.
  5. Click the Clear button.
This will clear all contacts off the BlackBerry.
Sep 27, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
RIM BlackBerry Curve 8310 Smartphone Logo
1,670 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
