Question about Dryers
Access the drum to replace felt
I need to replace the felt of the dryer and am having a bit of trouble lifting the top of the dryer to access the drum. Any advice on how to get in there??? GE Model # DRSR495EG1WW
To access the drum two screws need to be removed from the inside of the door. The screws are on top of the opening and hold the top of the dryer closed. Then you simply lift the top and slide it to the left to remove it, thus revealing full access to the top of the drum. Then two screws (left and right) need to be removed in order to remove the entire front of the dryer. Once the front is removed the drum can also be removed but for the purpose of replacing the felt removal of the drum is not neccessary. It should be noted that the felt sits only around the bottom of the drum and covers just over half of the circumferance of the drum. The felt should be position in around the opening of the inside part of the door. When replacing the front cover the drum will fit snuggly up against the felt. Replace screws, top and door screws and walla...fixed!
Posted on May 12, 2009
How do I replace the drum felt seal
You have to lift the top of the dryer. Be sure to remove the 2 screws holding the lint shute to the top first. Then you have to find and remove screws holding the front door and surround and remove them. This lets you pull the front side assemby forward giving you access to the front of the drum and felt seal. Be careful as the drum will be free and want to fall off the back rollers. This way is also used to replace the drum pulley.
Jan 08, 2016 | Dryers
Dryer making a loud noise
the problem is either going to be the drum bearing or the front upper and lower felt and glides.I'll list a walk-through for you if your interested .
1)The first thing you need to do is unplug the dryer.
2) You will need to pop the top of the dryer. This can be done with a flat screwdriver. Place the driver between the top and the front of the dryer and basically just pry upwards.
3)Now, that you can see inside the dryer, the next thing is to remove the front of the machine. At the upper left and right sides you will find a screw that holds the front to the frame of the dryer.Remove these screws and you can take the front off.
4) The glides and felt are located on the inside of the front piece you just removed.The drum actually rest on these and if damaged will produce a metal on metal dragging sound. If these parts are good, continue to step 5)You now have access to the belt and idler pulley, which is good because the belt needs to taken loose .
6) WIth the belt off spin the drum and listen for the sound that has been bothering you, if any sound other than a smooth sound is emitted when turning the drum your rear bearing is out.
7)You can remove the drum by lifting the back end up and pulling it out. Once you have it out the bearing will be exposed and the rest is just swapping out the old bearing and putting it back together.
Jun 01, 2012 | Dryers
Dryer squeaks
the rollers or belt idler may be corroded, use mineral oil or special bearing lubricant. DO NOT USE WD-40 OR 3 IN ONE OILS. you may find that they may need replacement.
Feb 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
Felt liner on right front side of drum slips out and drum grinds. felt liner with plastic spacers that is in the top center of drum is loose and wiggles out of place. Do i need to replace felt liner, or...
It actually sounds like you have another problem that is causing this one. When you remove the front to access the felt gasket check the support rollers because you might have one or both that need replacement. I would suggest replacing the felt also and yes it does require the high temp adhesive.
Jan 01, 2018 | Frigidaire Dryers
Replacing felt around drum - model dpsr610eg0wt
On the DPSR610EGWT if you open the dryer door and look at the top of that opening There are two small phillips screws that hold down the top of the dryer. Unscrew those, lift the top and then slide it to the left to remove the top. Next, near the top of the seams between the front and side panels is a screw. Unscrew the small screw and the front will lift off. Be careful because the drum is supported by the front and there are also wires connected on the left. Hope this helps!
Aug 23, 2009 | GE Profile Harmony DPGT750EC Electric...
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • remove screws from bottom bend of front panel
  • lift front panel off
  • remove doo switch cable
  • sent front panel aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Sep 06, 2008 | Dryers
Where is belt on dryer and how to fix drum won't turn
The belt on a roper dryer is inside the body, accessed and changed as follows
  • raise case lid
Notes
May 07, 2008 | Roper REX4634KQ Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Dryers Logo
367 people viewed this question
Top Dryers Experts
