I have a Coleman Furnace in my mobile home. It was working yesterda, but then stopped running through the night. The furnace has an error code which is flashing two times - Combustion Ignitor Switch Shut Closed. I have turned off the furnance and thermostat hoping a reboot would solve the problem, but no luck. Does anyone have a solution to fix this problem and get the furnace running again??
Our mobile home has a 1996 Coleman Evcon. We noticed dripping of water onto the front and back, dripping on the wires. A tech came, repaired the drip pan and cleaned the coils. Didn't help. The tech siliconed around the entire drip pan. Didn't help. The tech cleaned the entire unit where coils are. More water. What should I do next?
I have an old godman furnace GPM050-3 nedd to replace the circuit board, I allready got a new...
(More)
I have an old godman furnace GPM050-3 nedd to replace the circuit board, I allready got a new janitrol circuit board, but looks different, I need instructions on how to replace that
pressure switch keeps onening flue is clear, static pressure starts at .4 drops to .3 when burners...
(More)
pressure switch keeps onening flue is clear, static pressure starts at .4 drops to .3 when burners light tried another pressure switch, inducer motor, found white gasket has a tear in it could that be the cause of my pressure drop
Where can I buy an ignitor for this heater which is about 7 years old. I like the heater very much...
(More)
Where can I buy an ignitor for this heater which is about 7 years old. I like the heater very much but the cheapest price I can find an ignitor for is around $ 50 to $70 and I can buy a new heater ( another brand ) for a little over $ 100 at Lowes. I would like to fix the heater I have as it really works well when it runs. It ran for 7 years without anything done to it and that sells the product to me. Thank you, Lee Green
