Question about Sunbeam SBM1000 Microwave Oven
Microwave will not stop
My Sunbeam won't turn off. I can set the clock and set the timer to heat something up and it is ok, the timer rings when the time is up but as long as the door is closed, the light stays on and the glass tray turns with a fan going. This only stops when I unplug the machine. Help?
  • 473 Answers
Sounds like you have a bad door switch.  Will have to take control panel off and test switches resistance to see if they are opening and closing properly.  If a switch is stuck in or bad the microwave thinks the door is closed.  This is where I would start.  Let me know what you find.
Posted on Oct 13, 2007
Sunbeam microwave not heat
Place a glass pie plate in the oven with about 1/8" deep water in it. Turn the oven on high for about 30 seconds. If you get one small spot with intense boiling, the stirring antenna at the top of the oven is not rotating. It's usually driven by a small 60 RPM synchronous motor. To get at it, look for a pull-out plastic locking pin that holds the plastic dome or plate to the tope of the oven cavity. You may need to rotate the cover counter-clockwise a fraction of a turn to unlatch it. Sometimes greasy food vapor gets in there and gums up the bearings. Clean very thoroughly, but be careful not to bend the antenna blades. When you reassemble, make sure the antenna is properly seated in its bushing and engaged on its drive shaft. Repeat the test to see if you have even heating.
If you see no evidence of heating anywhere in the oven, check to see if the door switch in series with the transformer is malfunctioning. If the door switch is OK, you'll need a high-voltage measurement probe to determine whether the magnetron has failed, or (more likely) the high-voltage capacitor or diode is bad.
Apr 15, 2014 | Sunbeam Microwave Ovens
Our Magic Chef microwave timer counts down, but no longer cooks
Probably not because the timer works.Try the door switch.
Jul 03, 2012 | Microwave Ovens
Just stopped heating, making a louder than normal sound as well is there a reset button or something I can do. all else works, pad, clock timer etc, just not heating?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Jan 13, 2011 | Maytag MMV5156AAS Microwave Oven
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Basic Microwave Oven Troubleshooting Tips
Aug 10, 2010 | Sharp R-1214 Microwave Oven
I have a Sunbeam Microwave Oven SMW777 - 120V-60Hz. It stopped working two weeks ago - - I can set the time for the clock function but it will not cook/heat anything - won't allow me to set a time to cook...
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 25, 2010 | Sunbeam SMW777 Microwave Oven
Sunbeam microwave smw975
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Dec 01, 2008 | Sunbeam SMW777 Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sunbeam microwave doesnt heat
check  highvoltage circuit and magnetron and diodes and condencer and related parts, control circuit also check.
Oct 26, 2007 | Sunbeam SBM1000 Microwave Oven
Sunbeam SBM1000 Microwave Oven Logo
514 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
