Question about E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop
Bios problem comp has been crashing. message said bios problem.comp sent error message. shut down all cacheing in bios and comp now woudn't even boot up. changed settings back and comp still would not boot. got to boot in safe mode and dumped all recent downloads and rebooted. now can't get comp to even boot up in safe mode. Please Help!!
  • 781 Answers
Go to BIOS setup show how bottom of boot screen usually del key or f2 or f10 when in BIOS set to default screen will tell what key to press to do so
Posted on Jul 19, 2008
I have hp compac d530 but my vidio card does not work properly
Posted on Mar 21, 2008
    Sergeant:
  • 452 Answers
Cnge BIOS cell & then try .
Posted on Oct 13, 2007
No bootable device --insert boot disk and press any key
Sounds like your hdd has crashed. Look for a replacement hdd.
Feb 02, 2014 | Acer Aspire 5315-2326 Laptop Computers
I keep getting an error mess of 0xc0000225 when turning on my laptlop
We would like to know the exact error message or error code you receiving. Follow the below steps to get error message.
i. Restart the computer
ii. Start tapping F8 key
iii. You will see advanced boot option window
iv. Select " Disable automatic restart at system crash"
You may even check for the boot sequence order in BIOS.
BIOS DISCLAIMER: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
Mar 24, 2011 | Computers & Internet
My computer will not boot up keeps closing down
check how often it shuts down and if it shuts down when you start a particular application then start your computer and go to BIOS and leave it on there ( for example if your comp shuts down every 3 mins in normal mode then leave the comp on for 15 mins in bios to determine if it is a hardware or software issue then check in sfae mode the event log or error reporting if any hardware is causing the issue, update the drivers or try with new user or reinstall OS as last option.
Aug 10, 2010 | Acer Computers & Internet
My Hp Pavilion dv5000 crashed! XP cd displays error message!
If you are facing this issue while installing Windows, Most probably there is an issue with the memory card. If you have two memory modules try to use one of the memory modules in each slot at a time. If you have only one memory stick then try to use it one by one on each slot. If you it does not work then probably you might have to replace the memory stick.
Hope you find this information helpful.
Thank you for choosing Fixya
Dec 22, 2009 | HP Pavilion dv5000z Notebook
MAC PRO dual2.3- freezes, gray screen crash, freeze with hi fan mode,kernel panic reports, all require start button shut down. Some forums suggest ATI card failure. I'm lost.
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
Oct 22, 2009 | Apple Power Mac G5 Desktop
Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Sep 07, 2009 | Dell Dimension 3100 PC Desktop
My comp. was crashing at defferant time & message fault NTLDR
Use the commands
FIXBOOT and
FIXMBR in the
"Repair mode" of Windows XP installation or XP Recovery Console
for vista Recovery Environment or if you have recovery disk/disc you can use it
That error indicates a partition problem, you need to full format your harddisk and removing all partion and do a fresh install. Regarding your Win XP CD, just configure the BIOS to first BOOT to your CDROM
Hope this work for you ^_^
Jun 23, 2009 | Biostar M7VKQ Motherboard
HP a350n - stop message during destructive recovery
Before acquiring a new hard drive try a check disk. Boot on the OS CD-ROM - guess it's a Win XP - and through the Recovery console do a complete check disk. chkdsk /p and chkdsk /r.
Mar 26, 2009 | HP Pavilion a350n PC Desktop
PC Cannot Boot
Common windows problem,you need to wipe your drive and reinstall your operating system
Jan 08, 2009 | MSI K8MM3-V Motherboard
The PC doesn't completely boot up
u shoudl use xp cd and boot in formatt hard drive fresh install of your os
Jan 28, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop Logo
137 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
