Question about Kenneth Cole KC1104 Wrist Watch
New watch is losing 5 to 15 minutes a day
Bought in september 08 run fine for a while now getting slower, losing time evey day
    Problem Solver:
  • 5 Answers
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
Posted on Aug 11, 2009
Tag Heuer watch losing time
Make sure the voltage on the new battery is correct. Just because a battery is new does not mean it is good. That is likely the problem.
Apr 21, 2012 | Tag Heuer 2000 Classic WK1320.BB0316 Wrist...
My watch has been losing time all day long. It runs at least two to five minutes slow in the course. I bought it in 2006.
Overhaul is needed for your watch. It has mechanism, and it needs to be serviced every 4-5 years. Just imagine what would your car do without service! So, go and see the watchmaker.
Mar 01, 2011 | Longines Evidenza L2.671.4.78.9 Watch for...
My prc 200 is not working maybe its the battery?
These watches are "automatic" which means that the are self winding.
They will run for 1 -2 days before stopping. Shake the watchgently from side to side for a few minutes and it should start again.
(These watches need to be constantly used to keep them working).
Dec 12, 2010 | Tissot PRC 200 T17.1.586.32 Watch
Analog hands lose time when worn.
This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
Nov 23, 2009 | Casio AMW320R 1EV Casual Sports Watch
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
My skagen watch loses about 2 minutes per day.
yes it can cause that but it could be otehr things too you have a lifetime warranty send it to skagen they will fix it at very low cost
http://www.skagen.com/service/orderWatchBandParts.fx
Aug 05, 2009 | Skagen 170LTTM Wrist Watch
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Jan 10, 2009 | Rado Diastar Anatom Jubile watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Luminox 3001 watch not keeping time
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently. It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery. A.
Apr 08, 2007 | Luminox Navy Seal Dive 3001 Wrist Watch
Kenneth Cole KC1104 Wrist Watch Logo
1,234 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
