Question about Vacuums
No Suction + loud Noise
I have a Black and Decker VN2200-CA vacuum. I took the filter out to clean it as it was full of dust. After letting the filter dry, I replaced the filter back in the basket. I turn on the vacuum and get little suction with the sound of a jet taking off. I tried to install the filter and basket with the same results. What could the problem be? Thanks!
  • 75 Answers
Motor is probably is full of dust or needs replacing
Posted on Jun 30, 2009
Vacuum works quietly and well when using the wand attachment, as soon as it is lowered into 'floor vacuuming' position it makes a very loud noise but doesn't seem to lose suction.
Hi Ismaias, it's Jack at Dyson.
The issue you're describing sounds unusual. If you think the noise coming from the cleaner head and brush bar is excessively loud, you might like to follow the steps shown in the video below to make sure nothing is jamming or obstructing the brush bar:
If you're confident there are no obstructions, but your machine is still sounding much louder than it should be, please do not continue to use your machine. At this point, it would be best to contact the Dyson Customer Helpline directly so we can provide further assistance. If a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson warranty.
When you have your DC50 to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 22, 2015 | Dyson DC50 Animal Upright Vacuum Cleaner
Weak suction
if you've changed filters and checked for blockages it may need a new suction fan ,,you can download the diagram off the link below
http://www.ereplacementparts.com/black-and-decker-phv1800-dustbuster-parts-c-4167_8887_8897.html
Mar 13, 2013 | Black & Decker PHV1810 Bagless Handheld...
How do I clean filter on black&decker DustBuster pivot 18v
(The below worked with my 9.6v version - I assume the others in the pivot range will be similar).
If you open the lid (where the dust collects) you can twist the inner plastic filter about 30 degrees to unlock it. Then, with a bit of "fiddling" with the fold out part (press the unlock button and rotate the suction part as if you were going to use the unit) then, the plastic internal part and the whole suction bit will come off the motor part. Do this slowly as the inner filter will be full of dust and muck. You can then take the filter out, tap it clean in the bin and then wash and dry it with washing up liquid (gently) and allow to fully dry before putting it all back together again.
Nov 28, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
The vacuum has suction but the floor attachment does not. I have cleaned the clogs from the attachments and it still has no suction. What is wrong?
The hose may have one or more leaks or bad connection. The most common place for a large leak is at the connections to the machine and the connection to the handle.
I've seen some reviews that mention little or no suction when using the floor attachment.
Check some reviews here:
http://www.walmart.com/ip/Black-Decker-Cyclonic-Canister-Vacuum-Model-VN1400P/9195151#ProductDetail
Sep 11, 2010 | Black & Decker Black Decker Bagless...
Filters all seem clean and clear, suction is fine,but loud noise
Sounds to me it could be tha fan impellor.
This is vac's etc... email us if you need to.
vacs.etc@live.com
Nov 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
109 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
