Question about GE JVM2070 Microwave Oven
Fan does not activate when cooking
GE Profile JVM2070  The vent door opens when cooking starts but the fan does not come on.  Checked the fan and the fan does operate on low and high speeds. Everything else seems to be fine.
  • GE Master
  • 9,156 Answers
The problem may be on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Oct 22, 2007
SOURCE:
The vent fan does not draw air from stovetop
There is a wire mesh filter and a carbon filter on the under side of the unit. IF they are plugged then it wont draw air. The other issue is this unit has a dual option for installing the fan. One is to vent to the outside and the other is to vent to the inside, if the fan is not installed for the correct usage, you have no airflow either.
Oct 19, 2017 | GE JVM2070 Microwave Oven
GE Profile XL1800 light out and fan starts running when door is closed
It is not the fault with the fan but the trigger to the fan is shorted. It can be the DOOR SWITCH or the Transistor switch from the board. A fault or error on the processor cannot be ruled out. Clean the main board and reset.
Jan 31, 2013 | GE XL1800 1100 Watts Microwave Oven
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Venting of microwave - house stinks of bacon
Interesting post, because I have the same problem! I have spent the better part of today researching and taking our microwave apart (partially) to inspect the top portion re: outside vent. Everytime the microwave is on, the "active vent door" (manufacturer's term, not mine!) opens. Apparently this is normal. But it also opens when you turn on the vent fan, when cooking on the stovetop. I don't like this feature, because I think it 'overrides' the outside venting system. I double checked our outside vent to ensure that when this oven was installed, the person did in fact allow the flap to be open when the fan is on (he did). So I think what 'our' problem is, is that the microwave active vent sort of interferes with the outside vent, thus more of the cooking smell being blown into the house instead of the outdoors. I was thinking of simply disconnecting the gizmo that make the active vent door open each time you use the oven and/or vent fan option however I don't think that's a good idea as apparently the main purpose of the active vent door is to keep the electronics of the microwave oven from overheating. The more I read about this version of microwave, the less impressed I am with it. Lots of electronic issues with it. I am not fussy either with having the microwave over the cooktop. Sorry I don't have a solution for your problem but I do feel your pain!!!
Mar 21, 2010 | GE Microwave Ovens
Can this microwave be vented to the outside?
Yes, this microwave will vent either out through the top or the back. A damper will be needed if it was not saved when the unit was installed. A list of other items are listed in the installation instructions at this link To GE.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM2070 heats, no "fan" while running, no turntable
Hi. It sounds to me like the control PCB was damaged and is not switching power to the cooling fan or T/T motor.... Does the oven light work?
Sep 11, 2009 | GE JVM2070 Microwave Oven
Whenever I open the door on my GE Spacemaker XL mircowave the internal fan goes on. This is the fan that goes on when the unit is cooking and not the exhaust fan. It goes off as soon as the door is closed...
That is normal for it to spin for about a second or so becuase of switch changeover but should not remain on constantly when door is open. Have it checked up if it does not happen like the way I described it.
May 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker xl1800
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
Sep 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM2070 issue
what is the make and model number
Mar 26, 2008 | GE JVM2070 Microwave Oven
GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM2070 Microwave Oven Logo
91 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
