Checked the breaker, looked for a fuse on the wiring diagram and couldn't find one.
SOURCE: Hotpoint electric stove (older model push button) quit working
Did this solve the problem I have the same problem
The surface burner light goes on but the burners only get
slightly warm
SOURCE: We have a Hotpoint RB787 Electric Kitchen Range.
you will need to replace the control board that contains the clock readout,any power surges ruins these electronics instantly,this can be replaced by removing the rear cover on the back of the unit and remove screws securing the electronic module
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
