Cant get onboard sounds
Lost cd for mach speed matrix p4mdpt mother board please help
    Sergeant:
    Champion:
  • 225 Answers
Please download the driver from this site: http://www.machspeed.com/specs/discontinued.htm#p4mdpt, regards
Posted on May 11, 2009
Hi, I have the PM800BMS motherboard. I do not have a manual for it. How do I disable onboard video to use a video board in the 8x AGP slot?
All you have to do is go into the bios, go to advanced setup and enable the parameters for your video card. good luck!
Aug 08, 2011 | Mach Speed Matrix PM800BMS (878376000067)...
Installed a prescott cpu on my P4MDPT mother board and now my computer will not boot at all, no beeps either.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jul 01, 2011 | Socket Communications Mach Speed - P4MDPT...
I have p4mdpt mother board but grounded, what is the common cause?
common cause is that your house wiring is wrong some home owners connected the house wire's wrong so when you plug something in that is wired wrong you get this and the board should be earth grounded if you have a home depot or lowes goto the electrical department ask someone that you need to test you outlet to make sure that the wiring is correct at the outlet they will give you a outlet tester which has three lights check outlet and have corrected as needed
Dec 16, 2009 | Socket Communications Mach Speed - P4MDPT...
WILL WINDOWS VISTA 32 BIT WORK ON A P4MDPT MOTHERBOARD 100[? WHERE CAN I FIND DRIVERS FOR THIS BOARD?
comon dude.dont joke.even in the new computers it wont work properly.! try windows 7.but it depends on RAM also.
Oct 08, 2009 | Socket Communications Mach Speed - P4MDPT...
Mother board speaker drives not working
You can try looking for the motherboard sound drivers upload , it will be quicker to get a temp job and buy another I found
Jan 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Motherboard Drivers P4MDPT
make an iso file for this cd, or a rar file and upload this to rapidshare. Then share with us the link for download :)
Oct 18, 2008 | Socket Communications Mach Speed - P4MDPT...
D101GGC MOTHER BOARD AUDIO DRIVER
http://driverbyte.com/ntel-desktop-board-d101ggc-sound-and-agp-driver-wi_freedownload/
Try the above site contains about 5 different sound drivers for d101ggc motherboard
Aug 05, 2008 | Computers & Internet
P4MDPT Mother Board
you can check it on the manual of your motherboard.
Jun 06, 2008 | Socket Communications Mach Speed - P4MDPT...
Lost sound
I lost my mother board driver cd. mother board - ms-6787,
send me sound driver
Feb 26, 2008 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
