Question about Motorola Mobility Razrwire Bluetooth Headset - Black Frame Headset
Vista ! "v3guc driver not found modems pac" even when it tells me driver successfully installed !
"v3guc driver not found modems pac" with Vista for RAZRV3 Motorola phone ??
USb SXC -1080 modem of tataindicom causes problem with vista
the usb modem you are using is compatible with windows vista but for that u need to install the driver software ie sxc 1080 vista dialer 32 bits . you can download this software from the tataindicom site which is www.tataindicom.com. windows 98 and vista have different software compatibility.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Acer Aspire Computer
Hi there.
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Jun 30, 2009 | Acer TravelMate 661LCi Notebook
I can't install modem drivers for SB 5100 motorola (usb) on my laptop having windows vista. An error is showing that no cable found connecting the modem and computer. Can someone help me how to set this...
Here are the current windows Vista drivers from motorola:
http://broadband.motorola.com/consumers/products/SB5100/downloads/542708-001-install-utility-b.exe
Hope this helps you on your journey
Let me know if you have anything else.
I also would recommend you use ethernet since you do not have to install any software to make it work.
You will need to reboot the cable modem when ever you change how its connected also Ethernet/USB or if it was connected to a different PC.
Please Rate
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Install driver of dlink dfm 562is on vista
can you help me to install d-link dfm 562is on vista ultimate 64bit
Jul 01, 2008 | D-Link DFM 562IS (DFM-562IS) Modem
Facing ploblem while using TATA indicom USB modem in Vista Home Basic
Hi I'm Sathiya. I use Windows Vista Home Basic platform. I recently bought a TATA Indicom Plug to Surf connection. It had issues with drivers. I went to Tata indicom site and downloaded the latest driver for Vista. After installing the drivers, my connection is working fine. Make sure that you choose the right version.
Jun 27, 2008 | Microsoft Windows Vista Ultimate Edition
Sync Manager Problme with Vista with LG CU500
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where  you can find at http://www.bitpim.org/ .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
Jan 22, 2008 | Cell Phones
Driver Issues on Windows Vista Basic
As an adhoc solution you may try to download drivers for XP SP2, tell the driver installation applet to search for drivers from the folder you downloaded them to when it tells you this driver was not made for Vista tell it to install them anyway. It may not work but as this manufacturer is no longer in the modem biz vista is not supported by them at this time.
Jan 15, 2008 | Microsoft Windows Vista Ultimate Edition
Driver
no new driver or update needed after installation of vista, copy your old driver cd on hard drive, click properties on setup(aam6000ug driver or ... ) file and select compatibility and change the mode to windows xp sp2, then enjoy your win vista
Apr 25, 2007 | ASUS AAM6000UG Modem
Motorola Mobility Razrwire Bluetooth Headset - Black Frame Headset Logo
684 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
