Question about Toshiba 46HM95 46" HDTV
Still dark after replacing lamp
Toshiba 46hm95
after replaceing the lamp , got sound but no picture. followed the replacement steps again. but still no luck. I was wondering the lamp that came out still looks clear, not blown? is there a fuse thats keeping the lamp off?
  • peeps926 Oct 25, 2008
    have replaced lamp on 46hm95 for the fourth time. the cooling fan is running which i thought could also have been bad. after replacing lamp, i get sound but no picture. have gone thru manuel steps on what could be wrong with no success. have already spent over $500 on lamps and need help in finding out what else could be wrong. when i replaced the previous bad lamp tv came right on, now no picture but sound. help
    Sergeant:
    Champion:
  • 375 Answers
Possible ballast problem or cooling fans not operating
Posted on Oct 24, 2007
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
I have a 46hm95,have had for 4 yrs replaced bulb 3 times needs another.Any reason in particular why the bulb keeps blowing out?
No particular reason. There was a class action law suit filed against Toshiba for this. You can do 2 things to lengthen the lamp life though. Go into the TV menu and turn off the quick start feature. You should also switch the lamp to low power mode. Switch it back to high power mode when the picture gets too dark for your viewing pleasure. I hope this was helpful.
Mar 16, 2010 | Toshiba 46HM95 46" HDTV
Toshiba model #46HM95 picture dims and brightens occasionally and just started to turn off by itself.
Replace the lamp first. If that does not fix it then you will have to send the light engine to Toshiba to be rebuilt. The ballast is bad but is not available any more.
Dec 02, 2009 | Toshiba 46HM95 46" HDTV
Sound but no picture, tv turns off and on
It sounds Lamp is dead in your TV, how old is this TV and did you replaced its lamp recently?
Click Part Store to see required lamp image and price info.
Nov 02, 2009 | Toshiba 46HM95 46" HDTV
I have a tosihba 46hm95
Try replaceing the lamp
Jun 13, 2009 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95
your lamp is out, if you buy one it comes with instructions on how to change it, it will take about 3 nin's
Jan 07, 2009 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Red?Green picture
If you are connected to a HD cable box or sat. rcvr. using component cables, I would then suspect a loose or bad blue connection or cable. If you have Comcast and have their supplied flat component cable this is a common issue.
Feb 12, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 46" HDTV Logo
234 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
