Question about Microsoft Xbox 360 Console
I turned on my 360 and an error message popped up E 73
I turned on my 360 and an error message popped up it said E 73. i dont think i did anything unusual. i never connected to live or online on it and i dont think it overheated. need help bad...
  • Chris P.
    Chris P. May 11, 2010
    I am not a X-Box expert, what is an E 73, in lame man's terms?
    Novelist:
  • 149 Answers
From what I have read this is a general error that includes your ethernet port.
Posted on May 12, 2009
It has red light on the front and the screen says error 73
here is a webpage with some tips http://www.360errorcodes.com/xbox-360-error-73
also i you want to get it repaired go to craigslist.com and search up xbox repair
Jul 28, 2011 | Microsoft Xbox 360 Console
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
My xbox 360 has one red ring and i dont know if i need a new on or can i fix it
Solution
An error code will appear on the screen as well, which states what component the 360 thinks is faulty.
E67, E68, E79
These could all have something to do with the hard-drive. Try taking the hard-drive out from the 360 and playing without it. If the error message disappears, then your hard-drive is faulty, and you will need to get a replacement. If the error message still appears, then something else is wrong with your 360, and you will need to send in the 360 for repair.
Any other error message is not user-serviceable. You will need to return your console for repair.
Dec 22, 2010 | Microsoft Xbox 360 Console
Red flashing light in bottom right hand corner of xbox 360 arcade console. Says System Error contact customer support error code E 73.
the best thing to do is to contact the customer support because there are many occasions on which it can show you this message and you can't be sure which is which.
hope dis helped you?please rate
Dec 16, 2010 | Microsoft XBOX 360 ARCADE Console
My xbox 360 is coming up with E 73
ethrernet port error put the cord in and add presure down or by pulling up if that dont work call microsoft at 1-800-4my-xbox
Dec 16, 2010 | Microsoft Xbox 360 Console
My x-box360 is flashing red and showing an error message E 73
oh... you need to be concern about this and contact XBox Support for this E73 message, 1-800-4MYXBOX
Jun 12, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Apr 14, 2010 | Microsoft Xbox 360 Console
Xbox E 73 error
Hi Brett,
FYI. the 3yr extended warranty only applies for the 3RED LIGHTS and E74 issues only..if the console is already in the service center,you dont have to worry anymore,microsoft technicians will surely work hard to get it fixed. just wait 2-3weeks for the whole repair process,and you& your son will enjoy playing xbox in no time. :-)
May 15, 2009 | Microsoft Xbox 360 Console
5mins after turning back on e 73 is there
E73 error dont have anything to do with your harddrive. This is what E73 is E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
But I would almost guarantee it is the solder under the GPU which is the common problem for all overheated xbox360 systems. Wecan fix it for you if your interested please contact us for free estimate. xbox360fixer@verizon.net
Jan 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
108 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
