Question about Dometic RM2652 Refrigerator
Dometic fridge 'check' light keeps coming on...won't cool
We were preparing for camping and had the unit plugged into A/C and was cooling fine. The day we left, the 'check' light was on there was no cooling and it was in 'Auto' mode. I turned the power on/off several times over the next 2 days, but never cooled and check light kept coming on.
Now, it does look like the propane tanks went empty, but I was plugged into A/C power and the book indicates that this light should only be on if we are running on gas and having a problem. Is there some reason that the propane tanks being empty would cause this problem?
Thanks...
    Scholar:
  • 152 Answers
Yes , the check light is there to tell you that your out of gas yes this is true but the device which switches to power is not changing over which will not let the heaters work and will not start the process of cooling, I suggest to inspect the switch and ensure that this is the case first before consulting a mechanic.
Posted on May 11, 2009
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
Refer will not cool
The blue wire you are referring to, does not plug into anything. It should have a shrink wrapped rubber on the end of it. As for your fridge not cooling I will need for info.
If your fridge is level and on electric the rear coils of the cooling should be warm. If they are warm and the fridge is still not cooling then you will more then likely need a new cooling unit. Check out ArctiCold Refrigeration We keep it cold and Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY b838627c-cded-4581-a279-7ad685492c50.jpg 71841806-db73-4fb1-ab23-6e77deb169b9.jpg
Jan 22, 2014 | Dometic RM2652 Refrigerator
I have a Dometic rm3801 it was working fine on 120v and abruptly quit cooling all lights come on compressor and cooling fan don't run. I aam unable to try it on lpg. Fridge is level and cooling fins are...
If the rear cooling coils are warm and the refrigerator is level and there is still no cooling, then you more then likely will need to replace your cooling unit. It takes a couple of hours to do but you dont need any specialized tools. Check out ArctiCold Refrigeration We keep it cold Your unit can be found on ebay at under half the price of a new fridge. Link Below 11d6ec30-092e-426d-853a-24315c5d73c1.jpg Dometic RM3801 Brand New Manufactured Cooling Units LIFETIME WARRANTY...
Sep 25, 2013 | Dometic Refrigerators
Fridge check light is on and fridge not cooling
disconnect thermistor on back board let run if ok replace if not bad board or cooling unit
Apr 02, 2013 | Dometic RM2852 Refrigerator
Dometic rc1180 not cooling down on gas
clean all LP lines to ignitor if no clicking replace board
Oct 25, 2012 | Dometic Refrigerators
Fridge worked fine last camping season, this year light comes on in the fridge in AC mode, but won't get cold. It is a 3 way fridge in our motorhome, and we have always used it in electric mode only. I...
Also keep in mind that these units are very sensitive to being leveled; even a minor tilt will cause them to quit cooling. These units are not equipped with compressors as are home refrigerators which are not quite as fussy as the evaporative type.
Aug 04, 2011 | Thetford Norcold RV Cooler/Freezer
Hi...recently purchased a 2005 Roadtrek RV with a Dometic RM 2354 fridge in it...was getting things ready for camping and had the RV hooked up to 110 power...pushed on button for fridge and went through...
You said there was NO lights on the unit. The Dometic service manual says:
1. No operation - no panel lights: DC Volts
Fuse
Wiring
Upper Circuit Board
Lower Circuit Board
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
I would start with the DC volatage and track it back until you lose it. Most of the time it does end up being the lower circuit board though.
Aug 03, 2011 | Dometic RM2652 Refrigerator
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Dometic RM2652 Refrigerator Logo
611 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
