Question about Black & Decker BDDP100 10 IN. DRILL PRESS 1 EA 4250536
I have a Black and Decker drill press and the spindle is dropping out. Is there a clip or something that should hold it in? There is a groove in the top of the spindle for something.
  • 2,176 Answers
Generally on a larger drill press the spindle is a taper fit. What you would need to do is clean the taper and the socket thoroughly with break clean or something with will air dry. Then take a block of wood and place it on the chuck with the jaws retracted and hit the piece of wood to seat the taper socket.
Posted on Jul 10, 2009
Drill press
pull it apart and have a look ?? if you know how pete
Oct 01, 2013 | Drills
Drill press chuck fix
The chuck on almost all drill presses is held on by friction only by use of the tapered fit you mention. Make sure both the spildle tip and the chuck hole surfaces are completely clean and dry. Set your table so when you move the spindle down it will contact the table. With the drill OFF, put the chuck on the spindle and press it down on with the table as hard as you can without bending any handles or gears. This should be sufficient to hold it in place.
Jul 19, 2012 | Drills
I have a Black & Decker 78-936 type 1 drill press.
there are detailed instructions for this at dewaltservicenet.com type in the model number as 78-936 and you can download the operators manual with detailed information. If I have helped you would you please vote accordingly and thank you.
Sep 09, 2011 | Black & Decker Drills
The rotating shafts that hold the kneading blades in place keep sliding through the bottom of the bread maker
The spring washer that holds the spindle in place has probably come off. If you or your husband take off the bottom panel you might find it laying in there. Unplug your machine first of course before attempting any work. If you machine is like most it is a little spring clip that looks like a little horsehoe. Try to get it back on. It fits in a little groove on the very bottom of the spindle.
Feb 15, 2011 | Black & Decker B2300 Bread Machine
How do I exchange bits in the keyless * BLACK & DECKER 12-Volt 3/8" Cordless Drill
In Black and Decker drills when the drill stops turning the chuck spindle locks automatically. All you have to do is grip the outer sleeve of the chuck and turn it anti clockwise to open it. Turn it clockwise to close it. When you press the trigger to start drilling the spindle unlocks automatically again.
Jan 10, 2011 | Black & Decker Garden
How do I remove drill bit?
Your drill uses a key less chuck (the part that holds the drill bit). Grab the black spindle just below the drill bit and turn it clockwise when facing the drill from the back. Some drills have a locking chuck and only need to turn with one hand. Other drills don't have this option and use a 2 piece chuck. If it looks like there are 2 parts to the spindle, you will need to hold the the back part with one hand while turning the front part with the other hand.
Hope you find this useful
Mr Tin Man
Dec 29, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
I have a Guardian Power floor model drill press. The spindle will not retract. I would appreciate knowing how to fix this and where I can get parts. Thank you. Bill Powell
Can you move the spindle up and down with the handle? If you can't make sure the spindle lock is not on. Is the spindle clean and rust free , well lubed? Here is a link to a manual for your drill press: http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=15-331 You can order parts here. Usually the return spring can be adjusted with a nut on the left side of press. Possilby the return spring could be broken.
Jul 12, 2010 | Delta 15 331 15" 115/230V Variable Speed...
Can't remove the chuck on a drill.
There are one-way (non-reversible) and two-way (reversible) drills. Mine is one-way. Methods for chuck removal are different for these two types.
Procedure for one-way (non-reversible) drills:
Drills of this type have no chuck screw, so one have to hold the spindle with a wrench, than to sharply strike the wrench with a hammer to spin it off.
Procedure for two-way (reversible) drills:
Open the chuck up and in the bottom is a screw that holds the chuck on the shaft.The screw turns in a clock wise motion to be removed and then you can top the chuck off the shaft.
May 19, 2009 | Black & Decker Drills
Black & decker pivot plus bits are stuck
I had this problem too, an unfortunately, there's no manual on the black & decker site for this product.
I figured it out though! You have to push down (towards the motor) the chuck collar (cyllindrical black part which holds the bit). If you've tried this already, try harder - it can get really stuck and require a lot of force to push down.
Anyways, if you apply enough force, it will give and allow you to remove whatever bit is inside.
Hope this helps.
Dec 23, 2008 | Black & Decker Pivot Plus Cordless...
Black & Decker BDDP100 10 IN. DRILL PRESS 1 EA 4250536 Logo
306 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
