My laptop sound is not working
Hi..my laptop is not giving sound.if i raise its sound bar from speaker it is draged down at 0 level...what should i do?
  • 3 Answers
My laptop sound is too low i want high sound my computer model is dell indpiron 1525
Posted on May 12, 2009
I had onkyo 5.1 hometheater i cant raise the volume more than 40 how can i fix the problem ?
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
May 28, 2015 | Onkyo TXSR309 5.1 Channel Home Theater...
Volume control
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then
You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
Make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
Acer laptops run on the Windows operating system.
They also have built-in speakers that have a menu to change the settings.
All laptop speakers have a driver that tells the speaker how to function.
If the driver gets damaged or deleted, the speakers are rendered unusable.
Acer speaker problems usually have a driver issue that can be solved by the user.
Go to "Start," "Control Panel," "System and Security (or System and Maintenance)," "System," then "Device Manager."
Type in the Administrator password, if you are prompted to do so.
Click on "Sound, Video and Game Controllers."
Right-click the name of your Acer speakers and select "Update Driver Software."
Click on "Search Automatically for Updated Driver Software" and allow the computer to download any updates.
Reboot your Acer laptop.
Raise Speaker Sound Levels
Click on the "speaker" icon located in the lower right corner of your desktop.
Raise the volume bar all the way up to increase the sound.
Select "Mixer" to raise the other volume bars all the way up.
Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select
properties at the bottom select use this device enable
Jul 15, 2013 | Acer Aspire 3610 Notebook
I have a toshiba satellite A200. Recently installed windows7 then the sound comes very scratchy and only on right side. Even the headphone aswel. I replace my laptop speaker but didn't work and I also...
Hello there, go to the menu and write down sound, look for the sound folder then open it.Right click the speakers that you are using, goto levels then click on the balance button, make sure that there both in the middle of the bars, then press apply, then ok.
Hope this helped.
Jan 30, 2013 | Computers & Internet
Loptop audio sounds and speakers is not working
Hi. How are you?
1. Check if the volume control on OPERATING SYSTEM is mute or volume down at 0%
2. If the sound card is working on laptop, sound will come through speaker or headphones plugged into the line-out of your laptop.
3. If there is sound on the line-out. There is a chance that your laptop speakers are not working.
Now, what are the reasons?
It might be cause by excessive volume through laptop speaker, which are small and not designed ffor multimedia playing.
It might be cause by use and wearing.
God Bless You!!!
Hope it helps.
Remember to rate solutions, to keep fixya.com working for you!!
Feb 21, 2011 | Computers & Internet
How to unmute microphone (microsoft Vista)
::Look EASIEST WAY OF THEM ALL RIGHT HERE::
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple smile.gif I hope I was able to help someone with this... wink.gif
Dec 26, 2010 | Computers & Internet
Speaker volume is too low how can i increase it
Hi
Normally there are keys on the keyboard mine is on the bottom right of the keyboard showing a up key and a down key use the Fn key as well as the up volume key and that should take the volume higher
if that dont work go into control panel sound and audio and raise the level in there
Nov 15, 2010 | Acer Aspire One PC Notebook
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Jun 05, 2010 | Hitachi Televison & Video
AUDIO DEVICE IS RUNNING PROPERTY HOWEVER NO SOUND OR ICON IN TRAY. UNABLE TO PULL UP CONTROLS TO SET VOLUME LEVELS. AN SOUND DURING START UP OR SHUT DOWN HAS WELL
Go to start menu ->control panel->sound and audio device .
Then enable check box "place volume icon on task bar .
You can also set volume level from speaker volume .
If still problem then uninstall old sound driver and reinstall it.
Then it works again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 19, 2010 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
