Question about Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis 27062, the lid lock broke
Kenmore Elite Oasis 27062, the lid lock (its a small gray plastic piece) broke off....where can i order part and how to replace.... if you stick lock back into hole, you can wash but you have to jimmie it in order to open lid once load is finished.
Can you bypass the lid lock some how?
  • 15,935 Answers
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How to by pass the lid lock switch on a Kenmore elite Oasis HE washmachine
Not a real good idea except under emergency situations, as the lid lock is a safety switch to prevent access to the washer during spin cycles when the drum is operating at high speed and you don't want foreign objects (like hands) coming into contact with a high speed rotating drum or its contents. If you have the unit open enough to cut the wires, you had enough access to replace the switch, which you can get at SearsPartsDirect.com or any Sears Service Center in your area. If you are hell-bent on operating the machine in an unsafe condition, just connect the bare ends of the wires with a wire nut, which will perform the same circuit connection as the closed switch. Tape the connected wires away from any moving parts, don't let any bare wire come in contact with any metal and keep the lid closed during all parts of the wash, rinse and spin cycles.
Jul 25, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top loader 27062
See the following Whirlpool / Kenmore service manual for the Whirlpool Cabrio washer. The Kenmore Oasis is basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Also see the Sears Parts site for your washer.
Enter the full (###.########) model number and you should see descriptions of the major components and parts lists.
May 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Ok.. so I have already posted a question about my Kenmore elite oasis washer.. It was showing a dl error code, which I found out was a lidlock error... after looking at the lock closely, I see that they...
a replacement part should be sought and installed, you can bypass the switch, but the switch is there for a reason if you bypass it the spin cycle will not stop when opening the lid and injury to children or others can happen so this is not recommended
Apr 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Door latch to Kenmore Elite Oasis gas dryer has come loose. It will not close properly in order for dryer to start. Need instructions on how to repair or replace latch piece on door.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Jan 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Oasis HE 27082 and the lid lock bolt broke. How can I replace it?
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
You can access the lid switch at this point.
Mar 22, 2009 | Kenmore Washing Machines
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,527 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
