Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
My husband is trying to fix the washing machine, and we have DL F code, i know is something to do the the door, but he checked the door and I think that is not the problem!!!!We have a Whirlpool GHW9200lQ please help!!!!! why DLF CODE thanks
Mine did the same thing. The plastic part that locks the door is bad. My brother repaired mine instead of calling someone the part was 54.00, and it took him 15 minutes to fix. You could be looking at more than that if you call someone out. The front comes off easy.
Posted on Jun 23, 2009
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Error code dl then f
sounds like door lock issue but probably not lock itself remove top (3 screws) along back of top ..at rear of machine is control board ..if you are hearing a clicking noise at time door is supposed to be locking try wiggling connectors on control bd if i remember they are the pink wires if door locks then you have a bad connection on control bd may try wedging something under connector to help hold in place but only true fix is a control bd..good luck
Jun 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3t DL code
My husband and I had this same problem, but after visiting this website and reading through some of th posted solutions, we were able to fix our problem. Our 3-year-old Kenmore Elite H3 would not start on any cycle. It kept flashing the error code "dL/F", which we found out means "door lock failure." Taking advice, we unplugged our machine, removed the top panel, and rechecked the wiring. It worked! We think the wiring may have become loosened over time due to the jiggling vibration of our machine. Hope this helps you!
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
Door lock
dl meand door lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential Causes ? Door Lock Mechanism broken or removed from the Door ? Check Door Lock/Switch Assembly ? Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) ? Door Lock/Switch Assembly Failure Replace failed component.
Sep 22, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal De
