Question about Sharp Office Equipment & Supplies
Big streaks on copies from Sharp SF-7800 copier, not fax machine.
Getting big black streaks on copies made on a Sharp SF-7800 copier.
  • Sharp Expert
  • 255 Answers
Check the drum and its cleaner blade clean or replace.
Check the fuser unit ie the heat roller and pressure roller and clean or replace.
Posted on Nov 10, 2009
  • 4 Answers
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
Posted on May 11, 2009
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
My copier is a Sharp SF Model 2215. I replaced
It is the drum.
Reasonable cost? That's up to you.
Call a few service depots and ask. Then decide if you want to invest the cash.
Jul 14, 2009 | Sharp AR-M205 Copier
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
Jul 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
When trying to fax it shows a message in red that says Machine Error A6 and to call for support
A6 is a scan error, you should try to make a copy and see what it looks like, if the scanner is bad there will be streaks or just black copy. the file will be too big to transmit if it's black or deformed.
Jun 30, 2009 | Brother MFC-9420CN All-In-One Laser...
Getting big black streaks though copies
OK I am guessing this is a Laser Fax or an Inkjet Fax- If it's a Laser Fax,chances are you may have a "BAD" drum and if this is a Ink jet most likely and "Leaky" cartridge.
May 01, 2009 | Office Equipment & Supplies
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
Faxes coming out almost all black
take drum unit out, look on top and move plastic blue tab from 1 side to the other a few times. very important to make sure you replace the tab to the side it was originally on or you'll get a big, broad black band.
hth,
razors
Jan 06, 2009 | Brother IntelliFax-2820 Laser Fax
Sf 7800 sharp copier
-Did you try to replace the Toner Cartridge? if not try to replace and installed properly.
or check the Toner Cartridge if installed properly.
Sep 20, 2008 | Sharp AL 1215 Black and White Copier
Black streaks on paper when printing message
That green bar is the drum unit. Black streaks are indication of bad drum. Replace drum unit. Don't wait too long or it will ruin the fusing section as well from excess toner build-up. Big bucks!
Please do not forget to rate your replys please.
Nov 21, 2007 | Sharp FO 3500 Plain Paper Laser Fax
168 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
