Question about NexxTech (DR30G0) System
Channel what channel does the tv need to be on for the dvd player to work. all the wires are hooked up but i dont know wat channel or setting the tv needs to be on
    Problem Solver:
  • 7 Answers
You should have an input or source button on your tv remote control. Turn on your dvd player and press this button ( changing source from tv/cable to whichever video input your dvd player is plugged into ) until you get the dvd picture.
Peter
Posted on Nov 26, 2007
I don't know what channel to go to to be able to play my dvd player
where did you hooked up the connector wire coming from the dvd player, in the component input or at the RF jack of the tuner of the tv?. if you plug at the component input of the tv you will select AV1 or AV2 etc. in the settings. but if you hooked up into the RF jack you can select channel 3 in the tv but at this time you need to have manual tuned in the tv to get the signal coming from the dvd player or xbox.
Oct 13, 2012 | Emerson LC320EM9 32 in. LCD HDTV
I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Jul 18, 2011 | Televison & Video
I need help getting a manual for my tv so i can hook my dvd vcr combo up My tv is a 37ld450 flat screen> If you dont have info on ownners manual can you help me hook up the red yellow white wire...
What is the name and model of your tv?
There are two ways to hook up a dvd/vcr to at tv.
1. Coaxil Cable - From VCR Cable Out To Tv - This goes to the tv cable jack. Tv should be on channel 3 or 4 to use it this way.
2. There are Yellow, Red, White Jacks on the vcr/dvd player. There should be a couple sets actually. One set should say OUTPUT on them. The colored jacks go from the vcr/dvd OUTPUT and goes to the same color jacks on the tv that say INPUT
TV must be on an A/V or Input channel for this to work
That is about all there is too it. If you need more info, just let me know. I am more than happy to help.
Mar 30, 2011 | Televison & Video
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Hooking up to a sony tv need to know were the wires go and is there any set ups to be done
cables go from dvd player/vcr OUTPUTS to tv's INPUTS,
Then turn tv to Input or AV channel and you should be good.
Apr 19, 2010 | Hitachi 168589 DVD Player/VCR
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
I have a emerson 32 inch tv ewf2702. The remote does not work
try scanning your TV channels down or up depending how close you are to the first or last channel you have programmed, if you continue to move past those settings you should come to the game channel for your TV, if it does not go into your menu>channel settings>manual settings, scan to the game channel and make sure it lists as active if not make it so.
Dec 07, 2009 | Televison & Video
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
Can't get dvd player to work on this tv!!!
im guessing that you cant go to av mode because you dont have a remote, am I right? if thats the case you need to go to walmart and buy an RF converter. You can plug you dvd into the converter, then run a coax cable from the converter to your tv coax inout aka anteanna input, then depending on your converter switch your tv to either channel 3 or 4 and presto. it will hook up just like vcr's and onld nintendos use to. You can pick up an RF converter cheap at walmart or check e-bay, couple bucks and your watching dvds.
Jun 23, 2009 | RCA F36649 36" TV
NexxTech (DR30G0) System Logo
77 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
