Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Picture flashes and soft images
When the screen is mainly white or very light colored, the screen will go off for a second or two then come back on.  If it has the same picture on the screen, it will go off again.
Don't have this problem when the screen is less than half white.
Also, the picture seems to be soft, not neccesarily out of focus, but soft.
  • 143 Answers
Sounds like poor regulation replace regulator get back too me
Posted on Nov 02, 2007
Regarding Samsung LCD TV LN37A550P3FXZA. On 4/9/17 picture became too dark, looking like brightness setting is way too low and color saturation too high -- I'll call this the "Too Dark Picture."
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 10, 2017 | Samsung Televison & Video
Display fades away and colores waile reading
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info/toshiba-lcd-inverter-c-13/
Feb 26, 2013 | Toshiba Satellite Computers & Internet
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
I have a samsung DLP TV, model HLN5065WX. When I plug it in after a few seconds both the lamp, and temp lights flash on the front. It did have just the lamp light flashing and it would have horizontal...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HLN5065W 50" Rear Projection...
Digital Camera HP Photosmart M517 Want to take a picture of my computer screen to send by email. Flash goes off every time and leaves a bright white light that obscures the screen. Can I disable the flash...
Press the flash button (just under the viewfinder) to cycle through the flash settings. Your choices are Auto Flash, Auto Flash with Red-eye Reduction, Flash On, Flash Off, and Night.
If you want to capture the screen image, you're better off using the computer operating system's screen-capture capability. This will give you the screen exactly as it is, without the distortions inherent in converting to an analog image and then converting it back to a digital image.
Mar 15, 2010 | HP Photosmart M517 Digital Camera
Lcd screen: lighter images flash from normal to
You are probably viewing the preview screen in "Highlight" mode. To fix this, use the dial button at the back of the D80 and click up (or down) to see another depiction of the preview screen. It will show you different options until you can see the normal picture without the flashing highlights. Hope this helps.
NOTE: Please rate our help to keep this free service online
Sep 18, 2009 | Nikon D80 Body Only Digital Camera
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Animal Eyes
I've seen some of those white eyes photos. Some are down right scary. I'm sure you have encountered red-eye when taking flash photos of people. With some animals, it is not red - but white. .... Try to catch the animal looking away from the camera when you take that flash picture. Have someone distract him/her. ............ Fixing Demonic Pet Eyes http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Fwww.myjanee.com%2Ftuts%2Fpeteyes%2Fpeteyes.htm http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Ftlbtlb.com%2Ftlbimages%2Fmax2.html
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
