Question about GE 46GW947 46" Rear Projection Television
Crackle, off, on, now won't come on.
This sounds strange. first my tv started to crackle through the speakers and the picture would get some static for about 1 second, then the tv would turn off and right back on. it did this for about a month and now won't turn on. is it trash?
         lee
    Genius:
  • 1,694 Answers
Fixable! Bad IHVT ( flyback transformer ) Give me the service # off back and I can get you th part #..........T.
Posted on Nov 02, 2007
SOURCE:
Crackling static in sound
reduce the volume of the microphone
Mar 25, 2014 | HP ProBook 5310m (FM997UT) PC Notebook
I get static and crackling sound out of right speaker, then it blows the speaker fuse, Sanaui au-999 what is wrong
Any of the transistors in the right channel power amp section circuit will have the fault. Check it. A very skilled work indeed.
Apr 15, 2012 | Audio Players & Recorders
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
TV is crackling
From the speakers or from the inside of the unit. On all modes, eg. normal tv + digibox/scart input???
Apr 05, 2008 | Televison & Video
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Sound interference
As you there seems to be interference via sound as the picture is fine. the interference is a crackling noise& tv is old 1 CHECK SPEAKER 2 so in that case tunning in sound section is disturb get it tnnned. 3 any components in sound section has done defective(SIF)SECTION. 1 CHECK SPEAKER not matching or paper torn or paper cone hard.
Sep 17, 2007 | Televison & Video
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
GE 46GW947 46" Rear Projection Television Logo
85 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
