When I turn it on it becomes always in standby.
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
What could be the fault with the Supreme- Galanz model KFR-25GW/A4 when switched on goes into standby
check that the temperature setting is not at or above ambient temperature as the machine will go into standby until the thermostat is activated by a higher temperature that what it is set at.. So if the setting is 35degrees and the room temperature is 25degrees it sensors that it need not turn on and will go to standby until the 35 degrees becomes less than the 25 degrees.
Apr 25, 2014 | Oldsmobile Cutlass Supreme Cars & Trucks
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
I have problem with my Dell PowerEdge 1430 xeon. the device can't start up. every time I push the power button on, I always become to 'standby' status, with LED indocator 1 & 3 ON and the...
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Remove all PCI cards and see if you see if it powers on. Check USB ports too.
Jun 22, 2011 | Dell PowerEdge SC 1430 (bscwfk1) Dual Core...
Standby light won't turn off on receiver r 840. Tried doing what manual says and turn off autostandby mode but still light stays on. ...how do you turn off ? i have tried everything..or does it always stay...
"Standby" means the unit has wall power but is not yet turned ON by you. When you turn the unit ON, the Standby light should extinguish and other signs of life should be evident.
It is basically an indicator that there is potential life in the unit. If it ever truly turns OFF, that is a problem.
Mar 18, 2011 | Audio Players & Recorders
My PS3 keeps cutting off by itself. It will cut off while I play a game and the red standby light cuts off as if the power cord is not connected. Then, when I try to unplug it and plug it back in, the...
ok whats happened there is your ps3 power cord has become a bit loose in their so get a expert to fix it
i would always recommend a expert to do it never do it unless you know what to do
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
The "on" light is always green, even if turned off. Why?
It occurs when your wii in the Standby, but WiiConnect24 is enabled with Standby Connection is enabled. the content can also be received when the Wii is left in standby mode.
WiiConnect24 can be turned on or off via the setup setting. While the console is in standby, the power LED indicates the current status of the standby connection,
  • Red indicating Standby - wiiConnect is off,
  • Yellow indicating Standby - Connect mode is on. If you hold the power button for 3-4 seconds, the Wii goes into standby mode with Standby Connect off. and WiiConnect24 will not operate until the console is turned on.
  • Green ...
Jan 18, 2010 | Nintendo Wii Console
Where is the button to turn off my technika dvd tv?
Apparently you can not turn it off, it always remains on standby unless you turn it off at the wall. Or maybe I'm just missing something as well.
Sep 05, 2009 | Televison & Video
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
